Question about Royal VF700 Cross-Cut Shredder
Power failure There is no power when plugged in to outlet. In the past, sometimes it would work and sometimes it would not work. What can I do to get it going?
Mine quit one day, (800 #) no help, just check for loose wires... I rewired mine and use shredder OIL (office supply stores) to keep it from jamming up.
Posted on Apr 30, 2013
    Genius:
  • 1,218 Answers
If it is dead and you have no lights and nothing runs the most likely the pcb is blown inside...give Royal a call at 1-800-524-0799 for parts and pricing.
Posted on Sep 06, 2010
What does a power supply failure on a tv?
??? what does a power supply failure on a tv look like ???
none of the buttons light up , nothing lights up no bars or stripes on screen , nothing !! cord is plugged into a power outlet and is on , but nothing no lights no sound (sometimes a high pitch squeal is heard )
Aug 03, 2016 | Televison & Video
Tip
How to Verify Power from a 110V Outlet
Video about How to Verify Power from a 110V Outlet
  • The first step of troubleshooting a power issue with a machine equipped with a power cord is to verify that the outlet being used is working
    • This video demonstrates a simple method of testing the outlet
  • Make sure that the outlet and appliance have matching plug and receptacle before plugging in
    • Failure to do so could result in injury and/or damage to electrical circuit and/or appliance
  • This procedure is a quick and easy way to test the functionality of a 110 volt outlet
  • Plug in a small appliance such as the fan used in the video and make sure the appliance works
    • If so, you know that the outlet is not your problem
  • You could also use a light, small lamp, or radio for this test
    • Any small appliance that you can plug in and turn on and know the appliance is working
  • This completes our demonstration of testing a 110V outlet for power
on Feb 11, 2015 | Proform Exercise & Fitness
Won't turn on
This is a clear failure of the power supply or the control panel due to the power outage and so will require that the power to the unit internally is checked. Sometimes this can be due to a fuse blown out or a control panel failure within the unit due to the intermittent fluctuation.
Nov 30, 2011 | Pool & Spa
No Power
loose wires connection or pc board
Aug 25, 2017 | LG WM-2277HW Front Load Washer
No power. Will not turn on
Not intended to offend;
1. If using A/C (house electrical power), please check if electrical wall outlet is active. Attempt to plug-in another electrical device such as a lamp, clock, radio, etc.. If the electrical wall outlet has top and bottom plugs, try the top and then the bottom plug to see which one works. Sometimes, the top outlet will not work, yet the bottom outlet does work. The wall outlet should be replaced by qualified technician.
2. If both outlets do NOT work, and the outlet is GFCI breaker protected, maybe pressing the RESET switch on the outlet will power-up the outlet.
3. If the outlet is NOT GFCI breaker protected, check your electrical fuse box for a tripped fuse. Sometimes, a tripped fuse is NOT visible. May have to trip the specific fuse or all fuses to off, then back on. Recheck the wall outlet.
4. Once your know the outlet is live, check the power cord (a/c adapter for laptops) to make sure they are securely plugged-in to both the wall outlet AND the PC or Laptop.
Will need more information once the above steps are taken:
Is it a Desktop or Laptop?
Make and Model (if known)?
Any lights (glowing) on the desktop or laptop?
Any lights on the A/C adapter if its a laptop?
Mar 30, 2011 | Computers & Internet
I have a GE gas range at my home in Ecuador. Ecuador being a third world country has frequent power failures. every so offen my ranges clock reads FFF and the oven doesn't work. in the past I pulled the...
Disconnect your range from your AC outlet. At this time determine the time of the day where the power supply is stable and plug the Ac cord the display must reset the time time you plugged in the cord. If no reset happens the control panel board is damaged and must be replaced.
Nov 30, 2010 | GE Kitchen Ranges
Getting intermittent report of "scanner failure". Sometimes starts up and runs, sometimes not.
if you get this error message as scanner failure it would be a hardware issue.. solution you could try is:- 1)connect the printer to the wall outlet and then check by making a copy..if its not working..then try the next step.. 2)perform a semifull reset on the printer..(unplug the power cord and then press # 6 button together and then plug in the power cord back and keep pressing those two buttons till the screen says semifull reset or till the scree changes from HP to another scree and then relese those two buttons) if its still the same then its time for you to change the printer
Jun 17, 2010 | HP 7130xi All-In-One Machine Printer
Will not power up
FirewallAvat: Your problem is likely because your battery is dead and the adapter isn't charging it. This may be due to broken connections in the cable from the adapter. Flexing often causes the wire inside to break near the plug. Generic replacement adapters are available, or the wire can be cut back a bit and a suitable replacement soldered on. The cause might also be broken solder connections on the main board at the power jack, This is common from stress due to the power plug flexing. It is usually possible to open the computer and resolder these connections, although sometimes there's too much damage from arcing before the connection fails entirely.
DocBrown: Does the power LED on your computer come on when you connect the adapter? If not, try the adapter in another outlet anyway. Sometimes one outlet in a strip can go bad. Check the output of the adapter with a voltmeter. If it's bad, replace it or try repairing it as noted above. If the adapter is good but the light isn't on, you might have the bad power jack as well.
Nov 08, 2008 | Compaq Presario M2000 Notebook
My Compaq Presario will not start since we had a power failure in our town yesterday. It seems like it is unplugged, but it is plugged in. Can you help?
Can you check if the power is connected to the ac outlet, and if the cpu has a power. If no power in the cpu even the power cord is pluuged in the outlet of the power source the problem is your power supply. Maybe the fuse blow up when the power is back after the power failure. But sometimes the cpu has no power but the monitor have a power it's also power supply failure the dc output of power supply is not working. the best solution is to replace the power supply with the same wattages or higher.
Apr 15, 2008 | Computers & Internet
Royal VF700 Cross-Cut Shredder Logo
95 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
