Hello again, You suggest there is a problem with the door latch of my washing machine as i tried to open it after stopping the machine mid cycle but it wont budge at all. i have tried to switch off the machine for it to reset but now that its the door latch that has a problem.....is there any way of going round the problem without calling out an expert ...can i do something with a screw driver or something similar...i just need to get my phone out as its been soaked in with the laundry for 3 days now...:-( Cheers!
  • 1 more comment
  • misswangeci May 06, 2010
    Thanks Taran,
    the make is SERViS and the writing on it is 6kg 1000rpm A+A
    guide me....:-)
    thanks for the suggestions - the problem is i cannot open the door at all. if i were to do that, i would then be able to follow through with the steps that you suggest. But how do i open the door....? the machine did not make the clicking sound that it normally does when its done with a cycle so something is wrong with the door latch internally....how do i get round that without resonating to 'violence' on the machine?
  • misswangeci May 07, 2010
    great help - thank you!
  • 10,515 Answers
Tell me the Make and Model, and i would be able to Guide you.
Thanks!!
Posted on May 06, 2010
  • taran_2005
    taran_2005 May 06, 2010
    Thanks for your response!!
    The Generic Procedure to Open the Door Lock is Either to Remove or Replace it. The procedure is :-
    You will need a cross head and two flat bladed screwdrivers (or
    similar).
    1. Open the washing machine door wide and undo the 3 screws in the hinge
    (support door,
    just in case it drops on your foot!).
    2. Once screws are removed, wiggle door up and down whilst
    pulling it away from the machine. Door should come off.
    3. Lay door
    down on a flat surface (covered with a towel to avoid scratches) with
    chrome trim facing down.
    4. Insert the tip of one of the flat bladed screwdrivers, into the small
    gap between the inner white door panel and outer chrome trim. To avoid
    damage, do not insert too far!
    5. Using the second flat bladed screwdriver in the same way, work your
    way around the seam, levering it apart. About halfway round the chrome
    trim should completely separate from the door.
    6. Undo the two retaining screws and carefully remove the broken handle
    mechanism (so that you know which way round the two springs and other
    new parts go).
    7. Fit together the new latch, springs, center pin and handle receiver,
    using the old one as guidance.
    8. Fit handle assembly to door.
    9. Fit handle to handle assembly the correct way round (this needs to be
    fitted to help align the chrome trim in the next step).
    10. Replace chrome trim (snaps into place)
    11. Refit door
    to hinge with the 3 screws removed in step 1 and test it opens and
    closes correctly.
    12. Sit back and admire your handy-work!
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    Sometimes pushing firmly on the door where the handle or latch is helps to release a jammed lock.Try this a few times and attempt to open the door.Be careful not to exert to much pressure when trying to open the door as you may do more damage. If the door still will not open it may be necessary to break the lock off.This is a tricky operation and removing the machine lid.BEFORE ATTEMPTING THIS YOU MUST REMOVE THE APPLIANCE PLUG COMPLETELY FROM THE WALL SOCKET and wear protective glove and sleeve as it involves grabbing lock from inside the machine and physically bending it back and forth to remove or release the door.The lock obviously needs replacing and should now be able to be removed fully with the door open. Unscrew and make a note of the wiring (usually a small plug) or 3-4 separate wires.Once removed you also need to check the latch which is the piece on the door that would normally fit into the door lock when it is in situe.This should have resistance when moved backwards.(Spring loaded). If there is no resistance the handle (often plastic) is probably damaged and needs to be replaced along with the interlock device.The handle often comes in a small kit comprising of the handle itself,a tensioner spring and a small rolled steel locating bar.Fitting these new components should sort out your problem.Please note that the door handle kit can be tricky to fit and therefor you need to be EXTREMELY vigilant when removing the old one.Make note of every small detail and exact orientation of all parts.Sometimes the glass from the door has to be removed to fit the door handle kit so be very careful when removing glass and again note the position of the glass on the rim that holds it.Check the rim for damage also and replace if necessary.Rims are bought separately and come as inner and outer rims.Remember be careful to note the exact way you remove the door handle parts.Simple enough to do if you take heed of these warnings.
    Hope i helped you.
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
Feb 10, 2013 | Frigidaire FTF2140F Front Load Washer
Cannot open the door of electrolux perfect balance washing machine
Hello Nina DeLuca - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 02, 2013 | Electrolux EIFLW55I Washer
MY WASHER WILL NOT OPEN THE LOCK SYMPOL IS ON
Try a spin/drain cycle once or twice, then try again to open the door. Clean the filter and pump drain
May 01, 2012 | Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
Mar 29, 2009 | Washing Machines
Dishwasher won't stop when door is opened mid-cycle
Welcome
You need a new door latch mechanism.
It is faulty and not doing it's job of over riding when the door is opened
Please remember to leave a solved rating before leaving
Dec 19, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Kenmore Washing Machine
check the lock switch on the front load washer sometime it gets stuck
Mar 18, 2008 | Kenmore 44042 Front Load Washer
Our aeg washing machine stopped mid-cycle it had in 4 pairs of trainers. it clicks from the door latch area too.
try the door lock. if not im afraid it will need a pcb witch a tech will have to configure.
Feb 12, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
