Question about RCA 27V530T 27" TV
"Unusable Signal" We have the 27V530T. The problem is that we went to watch a movie on DVD and "Unusable Signal" was on the screen. We have sound, but no picture. We have tried other video sources and get the same problem. Please help.
  • Gnbdesdfchjjk May 12, 2008
    Ditto. F27645 (year 2000)
Are these T.V.s progressive scan compatible? for using my psp? cuz i can do interlaced but i can do progressive. or is there a button you can press/hold to make it go to progressive mode or something?
Posted on Sep 05, 2008
    Problem Solver:
  • 7 Answers
Ok, I stopped short of going to Best Buy to get a new TV b/c my DAD suggested I pull the DVD player on another tv.
Dang it, he was right!. Same "audio no video" problem.
After playing with multiple buttons shooting blindly I found the [ I/P ] button restored the picture immediately!
This stands for Interaced or Progressive scanning:
from wikipedia
"Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternatively."
So, my Dad says that "TV s are based on the interlacing" technology. I must have picked progressive scan while I was in the dark fast forwarding last week.
Posted on May 12, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
I am using a SVideo cord to connect my laptop to the tv. I have changed the input to both video 1 and video 2 and it is saying Unusable signal.
did you turn on your external video on the laptop?Usually a combination of keys i.e;FN+ one of the F key, it will have a little tv screen logo on it.Or connect your cable and reboot your laptop.let me know if it helps
Nov 02, 2009 | RCA 27V530T 27" TV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Unusable Signal
I have 3 ideas.
Mar 27, 2008 | RCA 27V530T 27" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Unusable signal
Substitute video jumper cable....
Re-check video out hook-up on back of DVD......
Sub out DVD with different DVD / VCR for test......................T.
Sep 01, 2007 | GE 31GT660 TV
RCA 27V530T
sounds like you have a bad solder connection on the coil connected to the base of the horizontal o/p transistor. the flyback has the big red wire. ( do not touch, just for reference), to the left and forward a little on a heat sink will be the transistor. on the other side of the heatsink,( a little more forward), you will fond a small coil on the board ir is red & you can see the windings. locate this part on the bottom of the board & resolder this part. good luck.
Dec 24, 2006 | RCA 27V530T 27" TV
RCA 27V530T 27" TV
You may have a couple of problems here.. It souds as the tuner is intermittant and a common capacitor in the power supply is bad.. Depending on the chassis, and I think its a CTC 185 I think if your handy you can get a fully repaired board for this set at http://ptscorp.com. If you have no tv reoair exoerience, you should give back the set and be done with it. Its all up to you. This set will most likly cost 200 to 225 to have a shop repair it and I think itys not worth that. Good Luck
Oct 08, 2006 | RCA 27V530T 27" TV
RCA 27V530T 27" TV Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
