Question about Panasonic PT-60LC14 60" Rear Projection HDTV
Tv won't turn on.
I changed the bulb to my tv a week ago and everything was going ok but now when I turn the tv on the power button flashes green for a few seconds and then flashes red for a very long time. What can I do?
  • 46 Answers
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Posted on May 06, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
TV won't turn on
it is maybe power supply is damage,please check the fuse of power supply,if it is fuse is damage,you can change it.if fuse is ok,you can change power supply boards.when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Craig CLC501 15 in. TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
TV does not turn on, blinking green on off button.
that should be in the owners manual
techman
most sets havev a small door thathas has a screw on it and the bulb is inside a small cage you pull out
techman
May 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Panasonic PT-60LC14 60" Rear Projection HDTV Logo
271 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
