My clothes are sopping wet after the cycle is done...HELP!!!
    President:
  • 1,294 Answers
Find out where your filter is & clean out thoroughly, refit carefully.
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: how can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Posted on Dec 12, 2008
  • 1122 Answers
SOURCE: clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Posted on Apr 18, 2009
  • 1122 Answers
SOURCE: At end of cycle clothes are sopping wet
transmission clutch not shifing to high speed-mike
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: Kenmore 41748102701 Front Load Washer - no spin
replace the door switch mech it is a common problem with front load kenmore washers. cost under 100 for the part
Posted on May 04, 2010
heatman101
  • 43501 Answers
SOURCE: Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
Spin cycle not working.
would make one think perhaps the timer or control board needs serviceman to fix
May 11, 2015 | Washing Machines
Speed queen heavy duty has problem leaving some oil/grease spots on clothes, for a couple of years now. Now the past two days the agitation and spin cycle sounded out of balance, but when I rearranged the...
Oil spots on clothes is from a seal on the drum. The balance issue is from shocks or springs that may be loose or broken and the spin issue is due to transmission. You may have a problem finding parts
May 26, 2017 | Speed Queen AWN432 Washer
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Gcxrpo9odoww does not drain well
There is a pump that is powered off the main motor. If it goes bad it will not pump the water out of the tub. Are you sure the basket is spinning in the spin cycle?
Nov 19, 2011 | Washing Machines
When the wash is done the clothes are sopping wet. I tried putting fewer clothes in and they are still very wet. Checked the drain hose for a kink and it seems to be fine.
motor coupler-to test restart the washer in it's spin cycle, let the washing machine run for one minute, then open the lid and check to see if the tub is spinning. if it's spinning the coupler is fine. if it is not then the coupler needs to be replaced, can be purchased at any appliance parts store. good luck!
Jan 04, 2011 | Kenmore Energy Star 44092 Front Load...
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Clothes coming out of washer still soaking wet
Apr 18, 2009 | Washing Machines
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How can i fix my washer myself?
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
