Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Pool heater cuts off and on - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
  • 640 Answers
It could be one of these problems with these pool heaters. Make sure that you are getting sufficient gas to your ignition. Check your circuit breakers and power source to make sure you don't have a short. Your pump could be defective. Check it and it might need to be replaced. It could also be your pump relay or your controller. Check both of those also.
Posted on Aug 12, 2010
Ignition locked
This means that the heater tried to fire 3 times without igniting. Cut the breaker to the heater to reset and try it again. Sometimes when a heater hasn't been fired in a while spiders will build webs in the burner orifices. Check the one below the ignitor.
Oct 27, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Opened & cleaned pool. Haward 250 Heater woun't stay on.
Could be a dirty or faulty ignition sensor. This is the sensor that tells the heater that there is a flame burning normally. If that sensor gets dirty or fails, the heater thinks there's no flame even though there is and cuts the gas as a safety measure. Cut the power, remove the cover, and check all the wire connections to be sure the leads are clean and dry and snug. The ignition sensor is near the bottom. If that doesn't work, then the sensor might be faulty rather than dirty. Call a tech to replace it.
May 30, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Leak in heater after winter freeze
Yes you can just be sure to leave enough room to plumb it back in when your ready.
May 01, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
Pool heater will not stay lit
check your ignition status. if you have a pilot ,make sure its lit. if you have a glo ignitor, make sure its glowing when you turn on the heater. sometimes it will glow but it might be hot enough to open the gas valve. also be sure to check your gas supply and make sure you are getting fuel to the unit.your heater will not turn on if your pool filter mode is enabled.
Jul 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pool heater not working
sounds like it is not getting enough water flow. Check to see that there is water going out of the heater. Here is a site you can check trouble shooting guide.
Feb 21, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
57 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
