Question about Stallion EasyServer II Remote Access Server
How to connect a cisco console to stallion easyserver ii
How can I get the Cisco connect program....
I am assuming you are referring to the console ports on your cisco Router. You need a terminak emulation program and a serial port on your p.c. Once you connect to it set up the Vlan interface so you can use the fast ethernet interface to connect.
https://www.hilgraeve.com/hyperterminal/
http://en.wikipedia.org/wiki/List_of_terminal_emulators
Feb 05, 2015 | Cisco Computers & Internet
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
Cannot communicate with the access point, no info is sent back via telnet or any other method. I had my friend who sets up networks for a living try for 3 hours to set it up with no luck. He said maybe...
First thing you should try is to console to the device. Cisco has a proprietary console cable (serial on one end, ethernet-like connection on the other end). You can use PuTTy's (http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html) Serial option to connect via the console cable. Make sure PuTTy has the correct COM port selected.
To re-flash the device, you'll need the original .bin file or have a valid Cisco.com login to download a new one.
Let me know if you can get connected via the console first.
Jul 06, 2011 | Cisco AIR-LAP1131AG-N-K9 802.11a/b/g
Cisco 876w series
you have connected via a serial console cable? (blue) set your com port to 9600 8 bit no parity?
Nov 02, 2009 | Cisco 876 Router
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Difference between router
Type II routers are Wireless ADSL (Asynchronous Digital Subscriber Line) Routers.They are used as routers for connecting to the Internet Wi-Fi.(i.e)You may also call them as modem.Type II routers links a DSL to ISP(Internet Service Provider).You cannot change most of the Configuration of the type II routers, you allowed to change only few configurations.
Example ::
>>Cisco 3620
>>UTSTARCOM WA3002-g1
The Other Router like Cisco 1800 series /2800/ 3800/ 7600/ Catalyst 6500 Series, they are all Higher Routers, where u can configure and Program them, for connecting a LAN/WAN/MAN.
I hope is answered your question!!! Any more clarification, plz reply me!!
Thank YOU
Riz
Feb 18, 2008 | Computers & Internet
Connecting to console
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
Dec 25, 2007 | HP ProCurve 2524 24x10/100 Mbps Networking...
Stallion EasyServer II Remote Access Server Logo
52 people viewed this question
Top Stallion Computers & Internet Experts
David Payne
David Payne
Are you a Stallion Computer and Internet Expert? Answer questions, earn points and help others
