Question about RCA 27V530T 27" TV
Unusable Signal We have the 27V530T. The problem is that we went to watch a movie on DVD and "Unusable Signal" was on the screen. We have sound, but no picture. We have tried other video sources and get the same problem. Please help.
  • Anonymous Apr 12, 2008
    The dvd will turn on for about 2 seconds and go right back to the unusable signal..what is this..its frustrating..I just got this tv.
    Problem Solver:
  • 7 Answers
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Posted on May 12, 2008
  • Gnbdesdfchjjk May 12, 2008
    Ok, I stopped short of going to Best Buy to get a new TV b/c my DAD suggested I pull the DVD player on another tv.
    Dang it, he was right!. Same "audio no video" problem.
    After playing with multiple buttons shooting blindly I found the [ I/P ] button restored the picture immediately!
    This stands for Interaced or Progressive scanning:
    from wikipedia
    "Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternatively."
    So, my Dad says that "TV s are based on the interlacing" technology. I must have picked progressive scan while I was in the dark fast forwarding last week.
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
"Unusable Signal"
from wikipedia
Mar 27, 2008 | RCA 27V530T 27" TV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Video
Bad video cable is first thing to check. The output is composite or progressive? need more info on your configuration to solve. It almost sounds like the IC for the video is heating-up.
Jan 01, 2008 | Memorex MVD4543A
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
RCA 27V530T 27" TV
You may have a couple of problems here.. It souds as the tuner is intermittant and a common capacitor in the power supply is bad.. Depending on the chassis, and I think its a CTC 185 I think if your handy you can get a fully repaired board for this set at http://ptscorp.com. If you have no tv reoair exoerience, you should give back the set and be done with it. Its all up to you. This set will most likly cost 200 to 225 to have a shop repair it and I think itys not worth that. Good Luck
Oct 08, 2006 | RCA 27V530T 27" TV
RCA 27V530T 27" TV Logo
473 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
