I have a White/Rogers thermostat and Concord 80+ furnace. They have worked just fine for several years now. All of a sudden, now the furnace is heating and heating, no cooling, regardless of the setting. In other words, it heats instead of cools and goes way beyond the set temperature. What can this mean and how to I fix it?
  • jfletch51278 May 06, 2010
    I am confused as to how the thermostat can already be bad; it is only a few years old. It was brand new in 2006. What else could be the problem?
  • 713 Answers
Hi,the problem is possibly from the thermostat of your unit,the thermostat regulates the temperature provided by the unit,which means the excessive heating is as result of a bad thermostat,the solution to your problem is to replace the thermostat of your device,before it affects the pumping system of your compressor.
Thanks and take care
Posted on May 06, 2010
  • 1,284 Answers
Hi, all you need to do is change the thermostat, that's where is problem is from. The thermostat is bad.
Take care
  • Shehu Pro
    Shehu Pro May 06, 2010
    Hi, the thermostat is in charge of regulating the cooling system and once it's faulty, it will malfunction by making it too cold to control or hot as the case is now..
    Take care
How to reset my thermostat
Pull the batteries out (if there are any) and pull the Red wire off the control wiring (or just turn your furnace off) for 10 minutes...then reverse.
Nov 03, 2013 | whiterodgers White Rogers 7-day...
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
I also have a white rodgers 1F80-24 thermostat that all of a sudden the numbers on the display are all broken up. I have changed the batteries.........no luck. I have looked for the exact replacement,...
White Rodgers 1f80 24 - Compare Prices, Reviews and Buy at Nextag ...
Im not sure what your application is but this stat is for a heat heat pump operation or forced air with A/C and heating. If you don't need the heat pump operation and you are using forced air furnace make sure all connections are good as labelled and connected to the proper terminals at both the furnace and thermostat If you installed new batteries and programmed the system without connecting to the sub-base and the numbers are still broken up you should replace it. I have attached a link for you to follow and you can see multiple types of White Rogers on the site home page
Jun 08, 2011 | Heating & Cooling
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Rheem LX2000 intermittent start problem
check all wires are tight and good on both ends if you are not a sparky then turn it off first at the power box
Mar 01, 2009 | Heating & Cooling
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Nov 06, 2008 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
