Question about Samsung (SP1614C) 160 GB Hard Drive
Power off when i connect the hdd - Samsung (SP1614C) 160 GB Hard Drive
  • Ctrlr4repair
    Ctrlr4repair May 11, 2010
    is it an external harddrive or internal? When you turn your PC on your harddrive should be connected already before you turn it on. Otherwise that will seriously mess with your system. But if it is external harddrive being plugged in should not cause your system to shut down.
  • 153 Answers
Bro check your front pannel connector for hdd power supply or your power supply connector.
Posted on May 08, 2010
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
I have problem with my HDD SP144N It's power cable +5v not go to hdd bcoz power ic which is imidiately connected after power cable is burnt so hdd can't access 5v and hdd not working give solution ?
IF the HDD has not been damaged, buy a new power cable.
If this is an EIDE drive, and connects via a MOLEX power plug, you can buy a splitter to add an extra socket from one of your working plugs
Sep 08, 2010 | Computers & Internet
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Oct 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Samsung (SP1614C) 160 GB Hard Drive Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
