Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Remove dust ccd ixus 75
I have stains on all picture, lens is completely clean.
i tried to dismount the camera but there are too much screws and contacts... any fast fix?
thanks
    Brigadier General:
  • 11,967 Answers
Do these "stains" only appear on flash pics? Are they always in different places on each pic? If so, these are dust particles reflecting the flash back to the lens.
Posted on May 06, 2010
Mark on all pics, but lens clean
Unfortunately, it from your description, it sounds like some dust or dirt is on the CCD sensor. You can try opening and cleaning it if you're adventurous, but I recommend getting it professionally cleaned. You can easily damage the CCD if you're not extremely careful.
Jul 13, 2011 | Canon IXUS 970 IS Digital Camera
Turned on ixus 75 and i have a black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A of the link.
Dec 23, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera is slightly blurd when i take a picture
I would like to know more about the camera and the type of lens you are using.
A few problems could cause this.
I would try a different lens and see if the picture is not blurred.
Dirt or smudges on the lens can cause it.
The ccd could have some minor dust or dirt on the surface. If you clean this, be extremely cautious how you clean clean it and with what. Special kits are available for cleaning the ccd sensors.
Here is one link with some information. Review Rebel XSI
Here is a link from Konica/Minolta to clean the CCD
In all cases cleaning the ccd is a job which has to be carefully undertaken, otherwise the possibility of scratching it is high. Once scratched, you will need a ccd replacement, a costly project for sure.
If the problem is not in the ccd or the lens, then your camera needs repair. Call support at their website for repair information.
Oct 22, 2009 | Canon EOS Rebel XSi Digital Camera
Restart the camera
that u must cheak the lens motor . better u cleaned lens mottor sometimes dust gon the motor gears cheak that one
Jun 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When I turn my canon ixus 75 on I see a black sreen is all the camera functions. Viewing the already taken pictures I can see them all. When I take a picture it shows in view mode a balck picture. I guess...
No, if your camera is an Ixus 75, it's more likely that you're experiencing a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 15, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Hair and particles on pictures-not on lens or mirror-on sensor
You must have dusty mirror box area. Here is what you should do. 1. Remove lens from the body. 2. Blow out any dust from the mirror box area using can duster (careful not to spew out liquid). 3. go to menu and select mirror up or ccd clean mode. You can also set at manual shutter speed "B" and hold up the mirror. 4. Blow out dusts over the CCD sensor (Do Not Use can air! If any liquid sprayed on CCD the cleaning gets worse) so use Hand-squeezee air bulb. You can purchase one from any camera stores.) 5. test shots and repeat. 6. If this procedure did not resolve the removal of the dust, you can purchase a cleaning solution package and try it. I do not recommend it becasue our techs get lots of cleaning requests from these package. Remember, if you are using these solution, 1. Never give any pressure to the screen, just tissuie touch pressure only. 2. move circular motion as you mouth blow the air as you move. complete the motion exiting through the corner of the screen. Did not work? send it to repair techinician! Our tech cleans it for $49. 24 hour turn around and also checks the camera too. Good Luck
Mar 26, 2009 | Nikon D70s Digital Camera
Dark stain on display screen
it should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Dec 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
DSC 200 Images
The CCD image digitizer is always screwed directly onto the back of the lens assembly and will contain it's own data ribbon. Take it off the lens, then clean the CCD glass with alcohol and a q-tip.
Nov 02, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Black dot appears on screen and on picture
You can open the camera, be very careful to discharge or avoid the flash, IT HURTS!. From there, you can access the LCD assembly, if you take that off, you should be able to access the back of the lens. On the lens is a CCD assembly that is fastened down usually by star screws. The dot might be on the CCD, you can try cleaning that, or else if you remove the CCD that gives you access to the back part of the lens.
Oct 30, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
