Question about Ariens 34 In. Zoom Series Riding Mower
Won't start, but cranks, If gas is put in air filter it starts
  • 198 Answers
Check carb for gumming----you may have to dismantle the carb and clean all the parts with solvent.
Posted on May 07, 2010
Engine turns over about 3/4 of turn,won"t start,been running good,new batt,new plugs,new air filter
check and see if you have gas in the oil if you do rebuild carb if not replace starter is bad
Jul 12, 2014 | Garden
Cranks but won;t start, is it the fuel pump?
number one thing to do , are you getting spark , pull a plug wire at the plug side and put the screw driver in the hole in the wire off and hold it to ground have someone crank it over a few seconds and see if you have spark , if you are getting spark then you are not getting fuel you have to ck you fuel pressure should be around 40 lbs , but some cars vary but it is pretty high you can ck online for the right pressure , also ck your air filter believe it or not I seen some cars not start because of a dirty air filter . let me know how you make out
Jul 11, 2014 | 1993 Toyota Camry V6
Car won't start. getting spark, fuel. car sat for three years. cranks and will only start if gas in air filter but soon runs out of fumes and stops
Put some fresh gas in tank. Use starting fluid to aid starting.
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 18, 2014 | 1995 Buick LeSabre
Died as i was driving , won't start
Fuel filter,air filter,spark plugs,crankshaft sensor,any codes.
Feb 02, 2013 | 2006 Mitsubishi Galant ES
2002 Ford Explorer ran out of gas put gas in and won't restart. replaced fuel pump and fuel filter still won't start. Cranks but won't start
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
May 08, 2012 | 2000 Cadillac Seville
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Ariens 34 In. Zoom Series Riding Mower Logo
135 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
