Question about Sharp AR-M205 Copier
WHAT CAUSES THE FREEZING OF THE PANEL WHISLT ENTRIN' SIMULATION
IN ALL MODES AR;AL, SF,AR-M,
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    kjjdsh cv njs jkks
  • 328 Answers
Ar-Al models are digital .ar-m some models with color scan.SF models are old and analog.
Posted on Jun 01, 2010
What is sim 14?
Simulation 14 is Trouble Cancel (except for U2)
http://einfo.thecircledelivers.com:8081/Techs%20Folder/Manuals/Sharp_Digital_Copier_AR-M207,AR-M165,AR-M162_Parts_&_Service.pdf
page 39 lists all of the simulations and how to canceling out of simulation mode.
Feb 21, 2014 | Sharp AR-M207 All-In-One Laser Printer
How to reset the Maintenance indicator sign in SHARP AR 5618
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Dec 09, 2012 | Sharp AR-5320 Black and White Copier
AR-M150 shows h4 but it does'nt have interrupt key
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
Jul 16, 2011 | Sharp AR-M160 Black and White Copier
How to enter in the simulation mode for a sharp AR-5316 digital photocopier and change the settings
Try pressing #, *, C, *, to get into the simulation mode. To change user settings, try the menu feature. Good luck.
Feb 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Reset drum
Hello sir; after you replaced drum there have 4 simulation you have to do;
1, simulation26-7 to match the first digit of the four digit printedon drum.
2, simulation 24-7 drum film wear correction counter reset.
3, simulation 44-6 patch forming voltage.
4, simulation 44-2 drum mark senser level standard value is 90.
To get in simulation the procedure as follow;
1, press "clear", 'pause", "0", "pause". then enter the simulation number one by one. GOOD LUCK !!!
Jun 02, 2009 | Sharp Office Equipment & Supplies
Sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Feb 28, 2009 | Sharp AR-M205 Copier
Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Jan 24, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M205 Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
