Question about HP DeskJet 712c InkJet Printer
I want to remove the date at the bottom of the page when it prints
    President:
  • 2,976 Answers
If you're printing from a web page, you will get what is there. If you are printing from within a word processing or other program on your computer, you can change the headers and footers settings in the program. It has nothing to do with the printer. It just prints what is sent to it.
Posted on May 07, 2010
Testimonial: "Thanks, hntnfsh"
  • 591 Answers
Information in Headers and Footers come from whatever program you are printing from, not from the printer. Go into whatever program you print from and make the changes.
Posted on May 06, 2010
Testimonial: "Thanks but I guess you can't remove the date from the bottom of the page on yje HP deskjet 712. OR I'm not doing it right hntnfsh"
How to remove the date and page number from printed sheets
If you are referring to a page number that is appearing on printed documents then you will have to look at the software you are using. If it is a premade document like an PDF file you would need a program capable of editing a PDF. If you are referring to the date and page number on a fax you likely cannot delete that.
Jun 05, 2015 | Brother MFC-7340 All-In-One Laser Printer
Date shows up on bottom right of all photos
Page 157 of the manual, starts with the print settings of the pictures.
In the DPOF settings you can chose for dat and time on and of. More settings on date and time are on the following pages.
The manual is online.
Nov 01, 2013 | Canon PowerShot SD790 IS/ IXUS 90 IS...
How can i get to black and white mode, and take the time stamp off
The S6100 doesn't have a black-and-white mode as such. You could use the black-and-white copy mode, which is designed to copy whiteboards or print on paper ("Black and white copy", page 70). In addition, you can convert pictures to black-and-white using filter effects in the playback menu ("Filter Effects", page 122).
To turn off the time stamp, tap the bottom tab, tap the wrench icon, then tap "Date". Select "Off" ("Print Date", page 157).
The page numbers are in my copy of the manual. If you need a manual, you can download one from
http://support.nikonusa.com/app/answers/detail/a_id/17246
Aug 28, 2011 | Nikon S6100 Digital Camera with 28mm lens
I have reset the time on my printer and when I print a document that correct date/time are printed correctly BUT the date at the bottom of a printed page is incorrect. This would be the date that the...
the real date is printed from the computer and the wrong one is the default date from the printer...What you have to do is to get into the settings and correct the date into the printer..Look for the time and date in the main menu ..and select and correct it ..After that restart the printer and the problem will be gone ..This may be an issue resulted from a total reset made or a failure of the internal battery ..
If the dat ewill not be kept set after you correct it ...it means the internal battery need to be changed cause when it is unplugged it will not hold the settings ..
Aug 23, 2010 | Dell Dimension 4600 PC Desktop
Windows Mail (Vista) quit printing body of E-mail to my printers.
Check the email print settings. If settings are ok, do a repair for your software using the control panel->add/remove programs.
Thanks
Jun 24, 2009 | Microsoft Windows Vista Home Premium with...
Date on print
Are you using the PictBridge compliant printer for the prints? If so click here to read page 75 for the setting on the printer. Go to the bottom of the PDF file, use the arrow to go to page 75. Don't follow the paging on the manual book itself, because this is a soft copy of PDF.
If you get prints from photo finishing center, then you probably have to order prints with date and/or time stamp added on.
As far as I know, W50 has no time stamp setting. Every image file carries its own date and time for printers to add the time stamp if printer has that function.
Hope this can help.
Jul 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Date on photo
Follow the instructions on page 80 of this manual.
Jun 02, 2008 | Samsung Digimax A7 Digital Camera
HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP 1320 PCL
check the printer driver properties settings. look under printing preferences and check the settings there.
May 07, 2007 | HP LaserJet 1320 Printer
HP DeskJet 712c InkJet Printer Logo
111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
