Question about Garden
Looking for a main jet screw for model tvs90 tecumseh push mower
    Problem Solver:
  • 13 Answers
Need engine numbers or carburetor number located on the mounting flange, then we can come up with a part number.
Posted on May 06, 2010
How do I set the idle for Hoffco Ll'l Hoe engine
The start setting on most 2-cycle engines are as follows for the jets:
The Hi speed is 1-1/2 turns out from closed, and 1 turn on idle or low. Actually they are the same on 4-cycle too. The idle adjustment screw is a separate screw with a spring on it. This will push the throttle arm to give more or less idle. For more info, go to Partsree.com.
Jan 20, 2015 | Tecumseh Garden
Tvs90 governor to throttle
COMMENT CONNECTER LES BROCHES DU CARBURATEUR
Mar 26, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
Oct 29, 2011 | Mtd 22" Yard Machine Push Mower
Tecumseh TVS90 43710M 3.5 HP enginge. I was
the rule of thumb applies to your certain problemif you carefully inspect the throttle plate you can view which hole it belongs in by visually looking for any wear or paint removal around the holes the one with wear of use will be obvious
Jul 30, 2010 | Garden
Start but will not stay running
blocked main jet in carb most likely.
You will need to remove the carb and extract the main jet and clean it.
If you dont want to remove whole carb sometimes you can just remove the fuel bowl underneath and run a small piece of wire into the main jet from there. It takes a bit more finess but you wont have to worry about putting the carb back on.
You might just want to call a shop and find out how much carb service is with a regular seasonal tune up. Its very slow right now for a lot of shops so they might have the time and need to take a job like this for a reasonable price!
Jul 03, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Up and down rpms . think the air vane is out of adjustment.have taken apart carburetor ,new float,needle valve and gaskets. cleaned gas screen.air filter. spring on air vane maynot be in correct postion on...
This is almost certainly due to lean mixture. If your carb is adjustable, back out the high-speed mixture screw 180 degrees.
If there is no adjustment, then either the main jet is still partially blocked, or the carb has internal corrosion (in which case, you will need a new carb - it's not fixable).
May 09, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have a craftsman lawn mower with a tecumseh engine model# 143.956000 carbuator #(# on carb)1538F5R i need to know if the spring on the main jet goes on top or under the main jet. i got the carb in pieces...
LOOK CLOSE ON THE CARB THERE SHOULD BE A NAME OR SOME LETTERS OF WHO MAKES THE CARB GO ONLINE TO TECUMSEH AND YOU CAN GET A CARB BREAKDOWN DON'T GO TO SEARS TO MUCH RUN AROUND
Aug 22, 2009 | Tecumseh Garden
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
