Question about Sony Car Audio & Video
Sony Xplode CDX-GT630UI stereo shuts off and on
I have a Sony Xplode CDX-GT630UI stereo and it has been installed in my car for over a year and just out of nowhere the screen started pulsing with the beat of the song when i turn the volume up to 10 and anything passed 10 causes it to shut off and turn back on and repeats that. what should i do to fix that and which wire is the ground wire. it doesnt have a wire that is just black.
SOURCE: JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Posted on Dec 05, 2008
techman
  • 3130 Answers
SOURCE: Volume turned up, kenwood shuts off briefly...
If this is in a boat, I would check the amp unit for moisture damage, as a marine items is a specially built units that fends off water as well as moisture damage exposture. it does not mater if the amp is enclosed inside the hual or cabinet. The problem you are encountering is most likely because of a bad main amp unit, as if you disconnect the speakers and turn uo the unit, and it still goes into protection or shutdown mode, something is wrong with the amp. Like I said before, the fault is most likely due to water damage or moisture damage to the main printed circuit board. Good Luck.
Posted on Mar 24, 2007
  • 132 Answers
SOURCE: what is the light blue wire exiting cdx-l550x car stereo
THE BLUE WIRE IS USUALLY POWER ON SIGNAL TO AMP FROM DECK HOPE THIS IS HELPFUL GLENN
Posted on Nov 15, 2008
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
SOURCE: Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Posted on Feb 19, 2009
What size Jack for Front Aux-in?
You will be needing a 3.5mm jack for the sony xplode cdx gt200.
happy motoring
Jul 13, 2014 | Sony XPLOD CDX-GT200 CD Player
Sony xplode plug
The wiring diagram is on the first page of this installation manual: http://www.docs.sony.com/release/CDXGT640UI_install_EN_FR.pdf
Jun 22, 2013 | Car Audio & Video
I need to see a wiring diagram for my sony CDX-GT63UIW
You can download and print the installation manual and wiring diagram for Sony CDX-GT63UIW in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 12, 2011 | Sony CDX-GT630UI Car CD/ MP3 Player
I'm looking for the wiring diagram for a Sony Xplode CDX-GT20W
You can download wiring diagram in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Aug 30, 2010 | Sony Xplod AM/FM CD Player w/ MP3...
Need help with sony cdx gt62OUI mp3 player. Keeps resetting to factory settings when car is turned off??? HELP
who did the install??? sounds like the yellow wire is not connected to a constant power source. if you have a multimeter or test light, check to see if the yellow wire is hot when the key is off. if not, you need to find a source that is hot when the key is off.
Dec 09, 2009 | Sony CDX-GT630UI Car CD/ MP3 Player
Sony cdx gt63OUI front loader keeps resetting to factory settings when the car is turned off? please help..
check the yellow wire ,he needs to be connected to a direct 12 volt feed always maybe that´s all your problem
Music stops 30 seconds into the song
does the music stop? or do the sub(s) kick out. your amp might be to big for the sub rating , try turning down the gain
Jan 19, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Car Audio & Video Logo
190 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
