Question about Dell OptiPlex GX620n PC Desktop
Floppy disk failure but do not have a floppy disk Dell optiplex G620 have tried to remove it from the BIOS but dose not let me
  • 174 Answers
There should be a setting in the BIOS to ignore errors so you can get it to boot. It's usually set to halt on all errors by default.
Posted on May 06, 2010
Floppy disket failure
shibukpza,
If your floppy disk has failed you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= to purchase one. You can also click the link below. If you do not use the floppy disk you can boot into the system bios by pressing the F2 key at boot up. Once in the bios you can disable the floppy controller.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 19, 2013 | Dell OptiPlex GX620 PC Desktop
Desktop wont boot past floppy disk seek failure
There is a menu in the BIOS (set-up) menu that disables the floppy drive. This option enables or disables the floppy drive.
Aug 15, 2012 | Dell Computers & Internet
Floppy Diskette Seek Failure Drive 3 Not Found: Parallel ATA, PATA-1
If your computer has the old floppy disk drive on it, then Remove the Power Cord, Remove the Case and then remove the cable from the back of the floppy disk drive. Evidently the drive is bad.
If there is no floppy disk drive on your computer, turn the computer off, restart it and watch the screen for which key it says to hit to get into the System Bios or System Setup and hit that key. You have to hit the key when you see the message or it will not work and you will have to reboot it. Once you get into the bios check your devices and drives for the Floppy drive and set it to None or Not available ( It is probably set on auto or enabled). Also check your Boot Sequence or Boot Order in the bios and remove the Floppy Disk from being in the boot sequence or set it to be after the Hard Drive and CD Drive.
May 31, 2012 | Dell Dimension E310 PC Desktop
My Dell optiplex 210L boots up into a menu that says floppy seek failure strike f1 to continue f2 to run utility
You took your battery out and your computer lost all memory of what components it has installed. Hit F2 to get into the System Bios Setup. Look for your Disk drives and you will see your floopy disk drive there also. You should set the Floppy to Not Installed or None. It is probably set to Auto or 1.44.
Mar 18, 2012 | Dell OptiPlex 210L PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
I have an optiplex gx150 pIII, with a floppy drive. I downloaded the set up floppy so I could do a new install. after running the floppy disk, the messages says hit enter to continue. I place the xp sp2...
You don't need the install floppy... hit the F12 key when booting and you will get a boot order selection and tell it to boot to the CD. If it still doesn't see the HDD then you are most likely having a disk read problem with your hard drive. If that is the case you should boot into the system BIOS and see if the HDD is recognized there.
Apr 01, 2010 | Dell OptiPlex GX150 PC Desktop
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
Dell optiplex g620
Check your BIOS. If it rebooted chances are it might work if you change the way the BIOS sees and boots the devices. Try rebooting without the flash drive in. What happens?
Please remember to rate my solution!
May 07, 2008 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX620n PC Desktop Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
