Question about Dryers
Dryer not turning on
Our dryer won't turn on and it doesnt make the clicking noise when we turn the timer to the "minute settings"
  • Anonymous Mar 27, 2008
    dryer just stoped running in middle of cycle
  • tahoesharp Sep 09, 2008
    The push switch won't turn dryer on. I tried to replace the switch but that didn,t do anything. might the problwm be in the thermo fuse?
Mine stops if it overheats and you have to let it cool down and then press a reset button on the back. It could also be fuse or it may have tripped the breaker.
Posted on Mar 27, 2008
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Timer on dryer does not shut off
does the timer turn and keep turning? does it stay put? heat? try using a fluf/no heat cycle for a few minutes to see if it will turn off on its own. if it doesnt turn off then you need a new timer
Mar 21, 2010 | KitchenAid Dryers
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Timer just clicks and dryer doesnt turn
either you have a tripped breaker in the breaker box or the motor start switch is out
Jan 14, 2010 | Dryers
Timer appears to not be working, no clicking noise as I turn it, and the dryer will no longer turn on no matter the setting
HI, this absent clicking noise from the timer control is a signal of a failed timer mechanism. replace this damaged timer asap, if possible. it has failed.
Jul 12, 2009 | Hotpoint Ariston NWXR483EGWW Electric...
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
387 people viewed this question
Top Dryers Experts
