Question about Akai LCT2662 Television
AKAI 32" Power Malfunction
32" TV LCT3201AD - Will not turn on unless the set is unplugged from wall then plugged back in. Pushing power button makes light flash to green then it turns red again. Remote will not work either.
    President:
  • 196 Answers
Check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Won't power on.
Check to see if the cord is plugged in to the wall. Check to see if the wall outlet has power. If it does it may be the power supply or a burnt fuse in the TV and will need to be serviced.
Nov 22, 2010 | Akai LCT3201AD 32 in. LCD Television
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
Tv won't turn on
Although not a great solutin it does allow me to use my fairly new and expensive LCD TV. Heres what I do, UNPLUG THE TV FOR 20 -30 MINUTES, WHEN PLUGGED BACK IN YOU NEED TO VERY QUICKLY PUSH THE POWER BUTTON ON THE TV.
Let e know if this works fo you.
Mar 27, 2009 | Akai LCT3201AD 32 in. LCD Television
MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Jan 10, 2009 | Akai LCT3201AD 32 in. LCD Television
Sharp tv
First do a hard reset by unplugging it for a couple hours, then plug it in and try again to power it on. If no change, or power light just flickers then goes off again, your power supply may need rebuilt or replaced. Try this reset first, post back if no change.
Jun 20, 2008 | Akai LCT3201AD 32 in. LCD Television
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
See my other support issue regarding a simillar problem: http://www.fixya.com/support/t155367-red_line Since this is a row of dead pixels and the TV is under warranty, you need to either contact the manufacturer or even exchange it at the retailer you purchased it from.
Jun 22, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2662 Television Logo
319 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
