Why is my Broksonics CCVG3780 making a humming noise
  • tazmom777 May 06, 2010
    Why is my Broksonics CCVG-3780 making a humming noise
  • 2,335 Answers
There are three reasons that may be behind your LCD TV hum:
Your TV has a cooling fan which is making more noise than usual because it is failing or is working hard now because it is clogging with dust/foreign material.
Your TV's power supply is getting ready to fail; the hum is coming from the power transformer. Eventually it will now longer turn on if this is the case, although how long that will take is anyone's guess.
Your TV may be humming through it's speakers, rather than from the back of the unit. A hum in the audio channels from EM interference getting into your signals though a defective/damaged cable or through some very electromagnetically noisy components/power adaptors nearby.
I hope that helps.
Posted on May 06, 2010
  • 10,515 Answers
More Likely,Your TV have bad electrolytic caps, that need to be replace in the power supply section, especially the big cap too. You are getting a AC hum, because the caps are not doing there job to , filter out the ac, and that is why you have a hum, and if you take your TV in the shop, it should run around 100-150 for repairs.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Should motor make humming noise - instead of making no noise - if starter Capacitor is the only thing faulty ?
Not always, just replace the cap to start with. Sometimes they howl an other bearing make a noise.
Jul 23, 2017 | Cars & Trucks
4x4. What causes humming sound?
The used tires may be unevenly worn.
Jan 26, 2016 | 2007 Ford Explorer Sport Trac
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Humming noise from engine when driving lexus
Hello. I want to know more first, does it only make noise in motion or all the time?
Feb 17, 2013 | 1999 Lexus ES 300
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
Mar 01, 2011 | Computers & Internet
Speakers are making a humming noise
If the noise is accross all channels then it's most likely the large electroltic capacitors in the power supply. These filter out the mains hum 50/60hz. There might be two or more they will be the biggest! Even if you can determine only one has gone, it's best to replace them all.
Jul 12, 2010 | Kenwood VR-407 Receiver
My 1996 honda accord make a humming sound
are you sure it is a humming noise and not a vibration
May 09, 2009 | 1996 Honda Accord
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
