Question about Krups FME4 Coffee Maker
Door popped off my Krups FME4 drip coffeemaker.
I have a Krups FME4 drip coffeemaker. Today, I went to open the door to the coffee basket, and the door popped off. There's a long, metal rod that came out as well. It's the circumference of a paper clip, and about 6 inches long, then it bends to a 45 degree angle for about another 1-1/2 inches. How do I put it back together?
Just had the same problem today so I thought I would share with you how to fix it. The spring runs up through the door that opens, pop off the silver top and the wire where it makes a L, lock it into the top and put the silver top back on. The switch on the right is only to hold the door open. Good luck.
Posted on Jul 18, 2010
Water sensor indicates no water even though tank is full. Is repair possible and how?
It is probably just a calcium deposit stuck in the sensor intake. Try running a diluted vinegar solution through the full coffee making cycle. No coffee of course, and run clear water through a few times afterwards to get rid of the vinegar taste. You might need to do the vinegar a second time if the first doesn't fix it.
Oct 16, 2014 | Krups Fme4 12 Cup Glass Programmable...
I have krups xp7245. It just happened today after 2 yrs daily use.
These coffeemakers are not the easiest to work on, contact Krups and locate an authorised service agent in your area and run the fault by them, they will likely need to open it up to properly quote you. There are lots and lots of potential problems inside one of those machines. If you wish to look at yourself you are going to have to remove the top, sides and back covers. Side & back is one part. Even when you have it all exposed to not expect the fault to be immediately obvious, I have covers with cutouts so I can run it and look inside at the same time.
Feb 07, 2012 | Krups Small Appliances Espresso Machine
I am needing the double sensor (don't know what
those are named "contact thermostat" why you think they are brocken?
Feb 14, 2010 | Krups FME4 Coffee Maker
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Aug 29, 2009 | Cuisinart DCC-1200 Coffee Maker
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
I lost my manual for krups fme4 and i need to set the time of day can u help me
go to the krups website and download the manual:
go to consumer service, then instructions---maybe this link will work:
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME4
Jan 12, 2009 | Krups FME4 Coffee Maker
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
Krups FME4 Coffee Maker Logo
177 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
