Question about ASUS P4S533-X Motherboard
When I turn on the computer during POST the motherboard buzzer makes a 6-7 second long beep error code. Thanks in advance for your answer.
    Scholar:
  • 91 Answers
Hello;
The "beeps" your motherboard is making is an error code, designed to alert you of an error in an essential system component, such as a memory failure, general motherboard failure, video card failure, etc. When a PC is started, no matter the brand, it goes through a POST (power on self test).
The types of beeps is a code, and is often system specific; changing from the manufacturer of the system BIOS, (BIOS; Basic Input Output System). If you know the bios mfg, you can get a POST error code chart for that specific manufacturer online... this will tell you what component is in question...
I do find it odd that you've changed a motherboard, without trying to change your keyboard! Seems like it would be easier to troubleshoot a keyboard issue, than swapping out a motherboard.
I don't know how fast your post code error is coming out, but if you don't know the mfg of your BIOS, it splashes it on the screen at bootup, or you can check your manufacturer's website.
Posted on May 06, 2010
When rebooted computer beeps 3 times and will not turn on
Is it a long beep or a short beep? Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: AverageTime Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How To Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Tips:
  1. Still can't figure out what the beep codes mean? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum.
Jan 03, 2013 | Dell Precision T5500 Computer Workstation ...
Beep Error During POST
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Apr 10, 2012 | Chaintech CT-6AJA4 Motherboard
My Pm2Mp motherboard beeps 1 long beep and 2 short beeps and then continuous short high pic beeps. What does this mean?
Hi, Check the RAM's probably remove and re-fix them again making sure they properly fit into their slots. Hope this helps.Thanks! Please rate this answer.
Oct 24, 2011 | Mach Speed PM2MP Motherboard
My computer beeps every now and then. What are the beep codes for this motherboard?
here is a link tells you all beep codes
http://www.computerhope.com/beep.htm
hope this helps you
Sep 10, 2011 | Gigabyte GA-EX58-UD3R Motherboard
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 03, 2011 | Dell 3.0 GHz Second Processor for...
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
The motherboard makes a 3 second beep over and over.
Nick,
That beep code usually signifies one of the devices connected to your motherboard is having an issue and the motherboard is not able to past the POST.
You will have to do some digging to determine the cause of the problem. First step, remove the RAM, and see if the error code changes.
How did the bracket brake? If it is broken your CPU or CPU Socket might have gone bad.
If you're thinking about upgrading, you might as well ditch the PC2700-3200 and upgrade to DDR2 or DDR3. PC2700 is DDR which is becoming a phased out product line. Just FYI.
Hope this helps.
As a reminder, if this post helps, please rate it. Thankyou.
Feb 27, 2009 | ASUS P4S533-X Motherboard
Intel d101ggc making buzzer sound at equal intervals and then pc hangs.
OK this buzz is suppose to be a beep.
The device you described is called apezo electric speaker and is suppose to beep a post code to help define a problem.
If it's buzzing and not beeping there is either a fault with the piezo or the motherboard is not receiving the amount of power it needs to properly drive the speaker.
OK back to the post code. The patern is important it should be a series of long and short beeps. The fact that it is buzzing and not beeping may make it difficult to determine the difference between long and short beeeps.
Try your best to hear a pattern in it. Whether its constant beeps or 2 short 1 long or any other discernable variation please post back the number of beeps and if there is a long or short pattern.
please post back here
Thanks
Dave
Nov 21, 2008 | Intel D101GGC Motherboard
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
ASUS P4S533-X Motherboard Logo
250 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
