Question about Dell 2135cn All-In-One Laser Printer
How to print fax confirmations for dell 2135cn printer
SOURCE: I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Posted on Jan 15, 2009
tech435
  • 284 Answers
SOURCE: Panasonic DP-190. How do I
press the fax button, then press
function-7-4-start-1-2-start-2"should says always"-start-stop-stop
your good to go.
Posted on Jan 26, 2009
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
  • 26 Answers
SOURCE: How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Posted on Feb 19, 2010
frankzcomput
  • 268 Answers
SOURCE: My Dell 2135cn is printing very light even though
Most likely your printer head is clogged. This happens a lot to printers all the time. Sometimes they take 5-7 cleaning cycles before showing positive results.
I would recommend referring to the owners manual or support section of Dells website for detailed instructions on how to go about activating the cleaning process.
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
Posted on May 24, 2010
Can I print wirelessly from my Sony windows 10 laptop to my Dell 2135cn printer?
Yes. Dell has made available both 32 bit and 64 bit Windows 10 drivers for this device so it should work on you Sony. This printer is network enable but it is wired, not wireless so you will have to connect it to your network with a ethernet cable.
Here are the drivers:
Support for Dell 2135cn Color Laser Printer Change product
Here is the manual:
http://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers/dell-2135cn_user%27s%20guide_en-us.pdf
Jan 03, 2017 | Dell 2135cn All-In-One Laser Printer
My Dell 2135cn printer is printing Black when I'm calling for green. The color cartridges are full
If cartridge that has the blue & yellow (combinds for green), is low or out or clogged or defective, printer will automatically print black. Get some hot (almost boiling) water, then take color or all cartridges out of machine, put in container with about 1/4" of the hot water and let set for awhile. Do not put entire cartridge just the bottom where the print heas is located. The take paper towel and gently remove residual water from water. Replace, do print clean cartridge on your printer.
Edwin
Oct 11, 2014 | Dell 2135cn Color Laser Printer
I am having print quality issues on a Dell 2135cn MFP - print on the left side of the page is light.
Try removing the toner cartridge and gently rotating it back and forth. Often the toner will bunch up like a snow drift and where there is little toner you'll have light or no print. If that doesn't do the trick try another toner cartridge.
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
What is the part number for the dell 2135cn phd (print head device) Thank you!
I believe the part number is 330-1435 or P266C or Y459D
(these all are for the same part on the website - Dell uses multiple numbers to refer to the same item)
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=330-1435
Feb 10, 2011 | Dell 2135cn All-In-One Laser Printer
Dell 2135cn black toner prints light grey
The way I resolved the issue is to go to the Printer... literally walk to it (not via Windows or a Driver), Select Menu button on printer->Setup->Admin->Maintenance->Clean Developer. This will clean each toner cartridge or PHD unit, or to stir the toner in a new toner cartridge. Then it started printing solid black again.
It took me hours to resolve this but I hope it helps someone else and spares them the pain.
Aug 13, 2010 | Dell 2135cn All-In-One Laser Printer
No FAX status confirmation printed.
go into the fax settings (or setup) on the printer and make sure it is set to give a printed report after each fax reguardless of wether it goes through or not..
May 19, 2010 | Dell 962 Photo All-In-One InkJet Printer
Dell 2135cn All-In-One Laser Printer Logo
192 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
