Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
Line/Phono switch? Cant find them
I need to buy a replacement Line/phono switch for Behringer VMX100. Also fits VMX300. I have had no luck with Behringer, or other online parts vendors. Anyone help?
Salut.\,stie cineva de unde sa cumpar C.I pentru acest mixer VMX300...MULTUMESC.MOSU13@YAHOO.COM
Posted on Feb 23, 2011
  • Behringer Master
  • 5,603 Answers
Look on the switch for a brand name... often they use a lot of ALPS products. I normally search DigiKey.com and Mouser.com, and Allied electronics and Newark.com.
Behringer online is of little help. I have called them and got parts directely. They don't stock a lot and sometimes it takes a little while to get the product.
Posted on May 09, 2010
Computer will not recognize the unit
Call to expert help you to assist you to narrow down this issue +1(518)348-9393
Oct 16, 2016 | Behringer UFO202 U Phono USB Audio...
Why does my UREI 1620LE hiss on phono channels and aux 4 channel ?
are you using a phono pre on the phono channels?
Sep 15, 2014 | Music
How to link 2 mixers
VIa, XLR, TRS, 1/4 Jack, phono,,
Jul 19, 2014 | Behringer EURORACK UB2442FX PRO Mixer
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.
The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are.
The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
Dec 16, 2012 | Stanton C314 Tabletop CD and Mp3 Player
How can i connect a Behringer xenyx 802 mixer to a Fisher TAD 9315
What you've done should have worked on the video input. The phono will not sound like you'd want. Have you made sure the mixer is working correctly by trying it plugged into a different amp using the same outputs and cable?
Mar 14, 2017 | Music
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Sound quility is poor on phono side vol., E.Q, channel control are'nt responding properly sound like the sound is up to high
I think that something is wrong. The phono connectors are exclusively for vinyl turntables with phono cartridges. In case you connect a cd player or other compatible source at these connectors the sound is highly destorted and the result is terrible. Could you please clarify me what audio device do you use at the phono input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 02, 2011 | Numark Industries NUMARK M2 DJ-MIXER
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
188 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
