FixYa.com
Tags:
JVC KD-G310 CD Player
Jvc kd-g310, car stereo wiring map, ford escort...
posted by itsmekr on Mar 27, 2008
I have been trying to find this on line and am having some difficulties, when I go to an audio store the young snot just acts like I'm a dummy and try to sell me on them installing it, I am somewhat good with electronics and positive I can do this if I have the map which shows me where all the little prong things go in the holder and what wire connects to what wire.
Comment by itsmekr, posted on Mar 28, 2008
Some more info on the car is it's a 1990 Ford Escort LX Station wagon. I have the part in the diagram you gave me hooked up; but I am having some trouble figuring out what wires connect to each other.
Comment by itsmekr, posted on Mar 29, 2008
I found a better one for the wiring
http://www.the12volt.com/installbay/stereodetail/841.html
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 27, 2008
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 87%, 2229 votes
Hi itsmekr,
Pls refer to the image below for the JVC KD-G310 wiring. Should you need the complete installation manual, it is available here (as with the instruction manual).
Perhaps if you could post back with the year model of the Ford Escort, we can also try and provide the radio wiring harness information or at least a point to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comment by Benimur, posted on Mar 29, 2008
Pls try here.
Cheers.
Rating Locked! (?) itsmekr has rated this solution as Helpful
Solution #2
posted on May 23, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
the prongs go into the two holes on either side of the stereo as keys for the locks then you hook up you 12v(red) constant to the constant 12v from the car and hook up your ign. wire (red) to the ign. wire from your car(with test pen will show up when the key is turned over).. for your speakers you just have to guess or take off door panels and back panels to see which goes to which
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these In Dash Receivers problems?
In Dash Receivers
02 Honda Accord CD player does...
The radio works but the CD... Answer This...
In Dash Receivers
Audiophase CA-813 output specs...
Hi! I need to know the max... Answer This...
Ipod touch use.
I have an adapter that was used... Answer This...
JVC KD G310 Doesn't eject/work...
My JVC Kd G310 in dash CD... Answer This...
JVC KD-G310 in dash car cd...
I just bought a used JVC cd... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
