Question about Acer Aspire One PC Notebook
The start normal will not work its says the driver is not working"
    Scholar:
  • 36 Answers
This sounds like a driver problem.
Start the computer in Safe Mode.
Then go into the start orb, right mouse click computer, click device manager, click the plus sign next to the display adapters category, right mouse click the item in the display adapters category, and then click delete.
Restart the computer in normal mode and Windows will likely reinstall the driver.
Please post back to your success or lack thereof.
Good Luck!
Posted on May 06, 2010
I have a acer aspire 4738Z laptop. It contains scroller function with touchpad. Touchpad is working normally bt scroller is not working. How to start it again?
Your Touch pad Driver is not install or it is not updated. Download your touch pad driver from Acer Driver Download website and install it. It'll surely solve your problem
Aug 13, 2012 | Acer Computers & Internet
Every time that i install 1 drivers to my laptop, do i have to do a restart?
I've it asks for it, you " could " restart.
Normally the driver will work without a restart, but i've it wont work restart your computer.
Jun 11, 2011 | Dell Computers & Internet
I've got an Aspire 4935 and when I switch it on it starts up ok but after the Windows Logo the screen goes blank but it is still starting up normal.When I go into Setup mode the screen works.Yesterday I...
nvidia drivers have known issues with booting problems. Try this:
- Boot the PC in safe mode
- Uninstall the drivers
- Boot the PC in normal mode
- Download the latest drivers for the display card from the nvidia website
- Install the downloaded drivers
This must work
regards
Sandeep
Oct 26, 2009 | Computers & Internet
Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Aug 08, 2009 | E-Machines Celeron 2.3GHz (rb-t2385)
My monitor shuts down on windows startup and it is only working in safe mode. if i let windows startup normally monitor just goes stand by. i have ati radeon x1300/x1550 series driver installed and if i...
these cards do require that additional power be given to them from the power supply. Have you connected the card to your PC power supply via the 3 pin connector and power connector.
Also uninstall the driver via safe mode and let it redetect in normal mode then install the latest drivers for your card. Download from ati.com
Mar 14, 2009 | Sapphire ATI RADEON X1300XT 512MB...
Acer Aspire 5050 won't run in normal mode only safe mode
Try reinstalling the ATI Southbridge Drivers. The AMD website will have a link (it's on the same page as the Catalyst drivers).
You will have to use version 9.3 as the Radeon Xpress series is no longer supported with 9.4 and up.
Jan 07, 2009 | Acer Aspire 5050-3242 Notebook
Wont work on normal mode
This is usually caused by a driver or program that is wrong or corrupted.
Start in safe mode. Go to START then RUN then type MSCONFIG hit ENTER
This should bring up a window that has several tabs. Click on the tab labeled startup. Here are all of the software that is set to automatically startup in normal mode. Choose DISABLE ALL. Then Apply or OK and exit. The system will prompt you that it needs to restart. See if the system will now start in Normal mode. If so you are good to go. if you want something to startup again do the same as the above and select or "check" the items you want to start automatically. Do this until the problem returns and you've located the culprit.
However, if Normal mode did not return after the above steps, you may have to update the systems drivers, un install recently installed software or possibly restore system files.
Good Luck!
Jan 04, 2009 | Dell Inspiron E1505 Notebook
ACER Travel Mate 5520
it could be a vga driver fault check the driver in device manager.
if the device can not start, uninstall the driver and reinstall.
ONLY DO THIS IF YOU HAVE THE ORIGINAL DRIVERS!
Oct 28, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire One  PC Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
