Question about Hotpoint Washing Machines
All the lights are flashing on my hotpoint wmf541?
All the lights are flashing on my hotpoint wmf541! the machine will not start, tried to turn off power etc, cleaned filter, nothing will stop it
IFIXALL
  • 868 Answers
SOURCE: hotpoint WF541 fault
bad main control board
Posted on May 24, 2008
  • 1462 Answers
SOURCE: filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Posted on Jun 29, 2008
  • 3 Answers
SOURCE: Hotpoint WT741. When power on and 'on' button
Have had this problem on our Hotpoint WT741 washing machine. Fixed it this evening as far as I can tell. Seems it was a loose connection. Took the top off the machine and checked the ribbon connection to the display board at the top front. First, I removed the board (is held in by plastic clips - remove the programme selector knob first) and inspected to see it was okay then refitted it, making sure that the ribbon cable was pushed firmly onto the board. I then removed the rear access panel around the drain hose and checked the connections onto board at the bottom rear of the machine. I gave each connection a good push to check they were properly seated. Having done this, I have been unable to reproduce the fault with repeated switching off/on of the machine. It now appears to be working fine. I suspect the fault arises as a consequence of vibrations from the machine during operation causing one or more connectors to work loose - probably the ribbon cable on the front panel. So the problem should be rectified by checking these are properly seated. If you know what you are doing it's a simple job. Make sure you unplug the machine before accessing the machine and turn off the water supply. Don't attempt this if you aren't sure what you are doing and aren't confident with electronics.
Posted on Oct 27, 2009
Testimonial: "thank Martin it worked ! "
barkencoa
  • 3463 Answers
SOURCE: I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Thanks.
Posted on Jan 19, 2010
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
