Question about Epson Stylus CX4800 All-In-One InkJet Printer
Ink cardridge replacement
I replaced the black ink cartridge but cannot get pinter to print
Try cleaning the print heads (that option should be on your printer's menu). It does use up some ink, but in my experience with Epson printers, it needs to be done way too often. If that doesn't work, try another new black ink cartridge. I just had the same problem with an HP printer that was fixed by using another new cartridge.
Posted on May 06, 2010
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Replacement ink cartridge needs to be installed. Cannot locate cartridge housing.
These instructions are for color or black cardridges. Turn on the printer by pressing the power button. Flip down the front access door by grasping it on the upper right corner (just under the scanning bed) and pulling it down toward you. the cardridges will automaticly move to the right give you access to them. Press down on the top of the ink cartridge. This will release the cartridge. Slide it forward and out of the machine. Peel off the cover from the ink cardridge. This is a pink piece of plastic /tape like lift-off tab. Lift it up and off the cartridge.
Put the new cartridge inside of your Officejet J4580 by inserting it, label facing upward, into the open slot. Press it back into the unit and down lightly. You will hear it click into place. Close the access door. Wait for the alignment process to complete that will most likely require you to print a alignment page and place it in the scanner bed then press "OK".
I think thats about it
Dec 31, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Not printing black anymore
The link level display doesn't always show the correct information. To begin, try to wet the part where the ink flows, with a damp paper towel or just a towel. Sometimes the ink just dry up. If that does not work, you probably need another black ink. If there was a problem with the printer itself you would had been notify by the computer, you know, like a pop up window.
Sep 01, 2009 | HP DeskJet F380 All-In-One Printer
Empty colour cardridge, cant print black and white
Hi!
I'm afraid that most printers nowadays simply refuse to print unless you have ink in BOTH cartridges. No workaround. At least with an
Epson you have the possiblily of buying much less expensive generic refills...If you do this always try and find reviews of the brand of refills...caveat emptor! (buyer beware)
Sorry..
Aug 22, 2009 | Epson Stylus C46 InkJet Printer
Replaced ink in canon i850 printer. Now it will not print
Hello.
First make sure you removed any protective tape or caps on the
ink cartridge.
If there is a contact surface on the cartridge make sure
there is no dirt or fingerprints on the contact surfaces.
You can download the user manual here.. CLICK HERE.
Have a nice day...
/Tech5508
Feb 13, 2009 | Canon i850 InkJet Photo Printer
Lexmark X1270
Does the printer attempt to print? Did you replace the black or colored ink? If it was the black ink will it print in color?
If it prints in color, check the black ink cartridge for tape residue on the gold contacts. The blue tape will sometimes leave the adhesive on the cartridge and not the tape. It cleans off easy with a soft cloth.
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
It just wont work
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Oct 28, 2007 | Brother MFC 3100C All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
