Question about Sony XM-1252GTR Car Audio Amplifier
Nothing happening when i turn my car on the amp doesn't turn on not even the protect light comes up. This must of happened when my car was off because i would have heard it turn off but i just noticed it wasn't working today. I have checked the fuses and they are fine. Can you please help and tell me what the problem could be?
    Sergeant:
  • 300 Answers
Check your power and ground connections thoroughly. Also, check your remote turn-on connection. To test it, short the remote and the +12V connections together at the amp. This should force the amp to turn on. If all of the connections are good, there may be an issue inside the amp that will need repair.
Posted on Mar 27, 2008
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Turned off my 2006 Escape & now it won't start.
battery failure ,it does happen,cleanbattery terminals pour boiling water over terminals if they are corroded loosen clamps by undoing nut wiggle clamps back and forthand and retighten if no lights then ,iwould suspect computor failure -------- youdoit.com
Jul 25, 2009 | 2005 Ford Escape
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
No sound
unplug spkr from amp and leave rca and turn if this dont happen again check you spk
if it does happen again unplug rca and turn on and if this happen your amp may be bad
May 17, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Try to start car and nothing happens. replaced
Do the dash lights come on ? They should come on when the key is turned to the on position. If nothing happens check the engine relay. It is not too expensive to replace if you really want to eliminate that as the problem. Check all wires going to the starter and make sure it is wired correctly.
Feb 28, 2009 | 2001 Pontiac Aztek
The amp wont come on
sorry to have to tell u this but you blew your amp or just the channels this happens when you dont have the ohm rite for amp and speakers
Dec 20, 2008 | Nitro BMW-482 Car Audio Amplifier
Flashing Protect light
what are u using to play music??
Feb 12, 2008 | Infinity Reference 5350a Car Audio...
No power
Disconnect the sub or speakers and turn on the amp, see what happens. If the amp turn on without the protection light, then your sub is blown. Also check to make sure ALL your fuses are good including the one under the hood. If you have a meter, test the fuse for continuity. The problem can also be a bad ground.
Aug 19, 2007 | Kicker KX150.2 Car Audio Amplifier
Sony XM-1252GTR Car Audio Amplifier Logo
77 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
