Compressor will not kick on
Purchased a GE 12000 115v air conditioner less than a year ago. Went to turn it on for this season and it will not cool. The compressor will not even attempt to kick on even with lowering the digital thermostat as low as it will go.
    Problem Solver:
  • 8 Answers
(1)Check if elecric power is going to the unit.
(2) Check your Thermostat setting ,set the thermostat to the lowest setting
(3) Check the digital thermostat if it is in the cool position and automatic start
(4) Check the batteries on your hand held remote change if necessary.
(5) If you try these suggestion and it does not work you may check for loose wire in the electrical circuit or a defective control board. Let me know your findings.
Posted on Mar 27, 2008
SOURCE:
How long should the compressor stay on? mine stays on for (5) minutes,then stays in fan-mode
Kindly check your temprature settings and ventilation of outdoor unit. Your compressor is getting hot either due to low ventilation or your temprature settings are too high to cool.
Sep 06, 2014 | Haier HPF12XHM-LP Portable Air Conditioner...
Hi my Dometic rooftop (1999) used very little worked perfect untill this past year when we went camping. Fan worked ok, but no cold air coming out of ducts. Compressor seems to kick on, or at least a...
Check compressor run amps is correct with a ampere meter. If less, it's under gas leak. Keep your arm on discharge line (smaller pipeline). If no heat means no gas in the system. Find leak and arrest it. Vacuum and recharge gas.Better service the unit and check. Due to condenser & cooling coil, air filter, blower wheel are dust blocked will result to very less or no cooling. Helpful?
Jan 31, 2011 | Dometic Rooftop RV Air Conditioner
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
Compressor runs for short time then kicks off and blows warm air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | GE Profile ASM10AA Air Conditioner
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Aug 15, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
HVAC
usually the compressor is broken. its inlet valve and the exhause valve sometimes are not as gastighten as before.
if that is true, your room cannot be cooled down.the compressor has to be replaced.
May 28, 2008 | GE Zoneline AZ55H09D Air Conditioner
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
