Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door worked, 2 hours later didn't- just hummed good weather
Door went up and down yesterday after work, however went to use again last evening a few hours later and it just hums and doesn't lift the door. Verified the connections and nothing was in the way of the sensors, track, or disengaged. Craftsman 1/2 hp installed in Spring 1999.
    President:
  • 3,197 Answers
If it just hums when a button is pressed it could be the start capacitor. This sits next to the motor and is about 5 inches long and about as big around as a silver dollar.
Posted on May 06, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
I have a 2000 Volvo s80 t6 it was running perfectly fine 2 days ago yesterday I went to leave and the gear shifter would not shift out of park, a couple hours later in tried it again and it worked, it was...
sounds like the solenoid or the relay that locks the lever into park when the key is turned off may be playing up just to check try using the spare key see if you get the same problem hope this helps regards mick
Feb 28, 2015 | Volvo Cars & Trucks
Garage opener went up and the stopped mid way.. motor is humming but nothing moving.. sears 1/2 horse model 2000. Thanks John
Tries unplug,replug it back like about an hour latter.The unit now should be resetting itself,should work again.Still have same problems later,the motor should be check out and fix.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Went to start my car yesterday and it wouldn't start. Got it jumped it worked fine. A few hours later started it again and radio went dead car went dead what could it be?
sounds like alternator may not be charging check voltage at battery while engine is running need to see at least 13.1 volts if not have alternator checked and or replaced
Mar 21, 2010 | 2005 Nissan Altima
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
My internet has worked fine for the last year but then yesterday i was playing on it fine, i switched it off then a few hours later i went back on it but couldnt sign in nw it says it cannot establish a...
Sometimes on either ends of communication either the PS3 network or your broadband can have have a bad connection. Unless there is a serious problem i would assume that It will come back on in about at most a day or 2. If not check settings (ip address etc.) and make sure broadband hasnt been cut off.
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
179 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
