Question about HP LaserJet 3380 All-In-One Printer
Hp laser jet 3880 fax/copier/scanner
Not coping or sending faxes but will receives faxes,power went off/on a few times during the night
    Problem Solver:
  • 7 Answers
Need a new LIU board the cost about 50.00
Posted on May 28, 2008
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
HP 3050 Laser Jet: I can receive faxes but can not send fax? Help
Hello !
You need to reset fax settings first, go to the "Service" under the printers Main Menu and click on "Restore Defaults"
And then set the following settings under Fax Setup > Fax Receive Setup :
Answer Mode: Automatic
Rings to Answer: 2
Distictive Ring: All Rings
Now go to "All faxes" and change this settings:
Error correction : OFF
Fax Speed: Medium v.17
If you are using a digital line it would be a good idea installing a filter for the line
Hope this works
You can contact me on :
eliteprintersolutions@gmail.com
Jan 08, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
3880 scanner never has worked
HP has great on line(download and lookup Q&A) support for free.     Before going to too much trouble do this for me. See if the driver you installed,the disk,is for the version of windows that you presently are running. Sometimes disk installed drivers load ,even though it is for the wrong version of windows. Another possibility is that HP updated (Rewrote) the driver because it had a particular problem. You are hooked to the phone line , of course.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378060&submit.y=3&submit.x=6〈=en&cc=us
Feb 05, 2009 | HP LaserJet 3380 All-In-One Printer
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
Apr 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 3380 All-In-One Printer Logo
1,704 people viewed this question
Ben Johnson
