Question about Keurig Elite B40 Coffee Maker
Something is blocking coffee from coming out!!
When i hit the botton for coffee, it is dripping out! I think something is blocking it but im not sure what it is. I tried taking the k-cup out and cleaned it but its still only dripping out...one drip at a time! Is there anything else I can do???
    Sniper:
  • 92 Answers
Run it without a k-cup... Keurig will tell you to check for blockage at the upper needle with a paperclip... someone tried blowing into it with a straw to free the obstruction... which Keurig assumes is coffee/Tea grounds... or caked up cocoa mix, if you use that product...
Posted on May 06, 2010
Coffee is coming out in drips
Could be some grounds are blocking the nozzles. Maybe soak the nozzle in hot water for a few hours, then if you can use a can of air duster or blow into the outlet of the nozzle to try dislodge the blockage
Oct 15, 2014 | Coffee Makers & Espresso Machines
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
Anti-freeze leaking from the drivers side
bad hose or freeze plug it could be a lot of things. The coolant runs all through the engine.Maybe water pump gasket.
Jun 06, 2013 | 1996 Jeep Grand Cherokee
The motor starts and it looks like the water tries to go up the tubes but it doesn't. the steam part works. What is the problem
Hi there, I just had the same problem having bought a machine on ebay. Dismantle the brewing head, and take out the nut with the hole in the middle (the one with the spring behind it). then stick something small and pointy into the hole- I think inadequately dissolved limescale clumps at this point, and blocks it. Mine certainly had a thick plug of gunk blocking it at that point. Make sure you put the spring back in properly or it may start to drip.
Let me know if it works!
Mike
May 02, 2011 | Gaggia Evolution Espresso Machine
Very slow drip of water coming out. Takes longer and longer to make a cup of espresso.
Remove the screw and shower screen, make sure screen is not blocked with coffee oils.
Apr 06, 2011 | Gaggia Classic Espresso Machine
The coffee doesn't come out. I tried taking the
I think I have solved it. When it doesn't come out, I put my finger under where it drips out of and move the piece that's under their around. You can feel the kcup inside move. This seems to work. It is almost like there is an air bubble or a grind that blocks the hole temperarly. I don't understand it but it seems to be doing the trick.
Jan 15, 2010 | Keurig B70 Coffee Maker
The tray below the coffee cup holder has coffee in it all the time. is something leaking? love our machine
HI
The coffee residue is the result of the machine relieving its pressure into the drip tray. When it relieves its pressure, a little coffee residue with some water is released also, otherwise you would have an explosion of coffee inside your machine. If you are getting dry coffee in the drip tray you are getting an overcharge and that is not good. If you get residue under the drip tray, you have a blocked drain in the back of the machine just above the center of the drip tray.
Jul 29, 2009 | Saeco Vienna De Luxe Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Keurig Elite B40 Coffee Maker Logo
468 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
