Question about Fluidmaster INC #B1F09 9" Faucet Connector
Adjust water height in W/C
Need to raise water level in tank
  • 843 Answers
This depends on the type of flush mechanism you have - there are many. But if this is the simple old style float on a lever, just bend the lever down a bit. It it's the kind where the float is on a column directly above the input water pipe, then there will be a screw (usually) plastic that you can turn with your fingers. Turn it in the direction indicated by the Plus sign.
Posted on May 06, 2010
Testimonial: "Thanks For the help."
  • Al Kupchella
    Al Kupchella May 06, 2010
    Oops, don't bend it down, bend it UP!
How do you adjust the water level on the Toto CST604 CEFG toilet?
Water Level Adjustment
Depending on the manufacturing plant, you may have one of two of the following fill
valves:
Type A
Type B
Water Level
For Type A and C Fill Valve:
Refer to the water level (WL) setting marked
on the inner wall of the tank. Allow the water to fill the tank. Turn the adjustment screw
clockwise in the (+) direction to increase the
water level height (see Illustration 1). Turn
the adjustment screw counter-clockwise in
the (-) direction to decrease the water level
height. Flush the toilet to verify the correct
water level. Adjust as necessary.
For Type B Fill Valve:
There are no water level adjustments. The
fill valve has been preset at the factory
See page 7 of the linked manual.
J
https://www.totousa.com/filemanager_uploads/product_assets/0GU048Z_TOILET_IM.pdf
Feb 20, 2018 | Toto Home
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    Raising water level in toilet bowl Niagara Stealth
    the water level in the pan is set by the exit pipe level and if it is raised it will only flow out again to that pipe level
    if you are ferefing to the cistern water level
    remove the top and adjust the float level or level control unit
    Sep 10, 2016 | Niagara Stealth Ultra High-Efficiency -...
    Adjust the water level in the bowl of a duravit toilet
    You can't. Water level is set by the design of the trap built into the ceramic base. Can only adjust height of water in the tank.
    Jan 07, 2015 | Duravit 0910100005 Happy D Toilet Cistern ...
    How do I adjust the Moen M5350 assembly to raise the water level in my toilet tank
    To adjust the height of the fill valve, twist the threaded shank in or out of the valve body. The height of the Fluidmaster 400a valve adjusts from 9 to 14 inches. On some models a clicking noise will be heard when adjusting the height, this is normal.
    See: https://www.plumbingsupply.com/how-to-replace-fill-valve-fluidmaster-400a.html
    Oct 27, 2014 | Home
    How do you adjust the fill level for a geberit fors inlet valve
    A "Geberit FORS Inlet Valve" is not a dishwasher part. It is a fill valve made for a toilet cistern. You adjust it by removing the valve, removing the blue "locking clip" on the lower part of the valve body, then rotating the valve body to make it longer/shorter (and hence raise/lower the height of the large float body on the side of the valve). Once done, reinsert the lock clip, and reinstall the valve in the toilet tank. You can see how to adjust it at this link
    https://www.youtube.com/watch?v=VU2W_zxgGKM
    Jul 04, 2012 | Home
    Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
    Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
    Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
    We replaced our 3 toilets with the Fluidmaster 400 and have had problems ever since. All the toilets are running water every 5 to 10 minutes and my water bill has doubled. What can we do?
    Hello- If you replaced old ball and rod set with new fluidmasters they will most likely need to be adjusted, not all toilet tanks are of equal height. You will have to adjust water height,meaning you must keep water level below fill tube located in center of the toilet tank. Adjustment is done from bottom of the fluidmaster, they screw in and out to adjust height. You will notice threads along the bottom part of the fluid master, on the inside of the tank,they adjust up & down! Goodluck!
    May 19, 2011 | Home
    Water level in bowl too low
    Hello, W/D, toilet expert, here.
    The tank has a water level line cast into the inside back of the tank. That's where your water level should ideally be. Now, there are a variety of water level controllers, so we'll hit on the major ones. But first, a little nomenclature, so you'll know what it isn't. If you remove the tank lid, you'll notice a tube in the middle that's open, and usually has a smaller tube inserted or attached to it. This is the overflow tube, and feeds water to the rim of the bowl. At the base of the overflow tube is the flapper, and it controls the majority of the flushing power. The flapper is operated by a chain connected to the flush lever. When the flapper is raised (flushed), the water level drops. On the left side of the tank is the water fill valve, The water coming from the house via the tubing under the tank goes into this valve assembly. Part of this assembly is the all important float.
    Older ones have the float at the end of an arm, As the water level falls, the float falls and operates the water inlet valve at the other end of the float, on the water fill valve. As the level rises in the tank, the float rises with the level and shuts off the water when it gets to it's pre-set level. This type is adjusted by positioning the float either by the screw adjustments on each end of the float arm, or sometimes by bending the float arm.
    The newer types have the float either built in, or the float surrounds the fill valve. The one that surrounds the fill valve looks like a very fat donut and is very similar to the older float arm type, just more compact. The water level is set by adjusting the linkage between the float and the water valve at the top of the water control valve.
    The newer newer type has all of the floating mechanism built in. But cleverly, there is an external adjustment for raising and lowering the water level. On the side of the tube, there are slots and raised dots on the lower tube. The upper tube has slots on the inside of it. There is a white locking tab between the two tubes. Here's how this one works: (Turn your water off first for adjusting this type). The tube is in two parts, an upper and lower tube. They are held in place by the locking tab, and by the slots cast into the two tubes (they intermesh) To adjust this type, you have to raise the lower portion of the locking tab to raise it off of the locking dots, and than revove it. Then, you push down slightly and twist the upper section to unlock it. Set the level higher or lower, twist the two parts back together, and reinsert the locking tab. The aim is to set the water level at the level mark on the tank. This type can be tricky; you'd do best to turn the water off to adjust this type, and turn it back on once you have locked it back in place.
    Best regards, W/D
    Aug 17, 2009 | American Standard Cadet 3 Right Height...
    Low water level in toilet bowl
    Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
    Apr 09, 2009 | Bemis Home
    Fluidmaster INC #B1F09 9" Faucet Connector Logo
    336 people viewed this question
    Top Fluidmaster Plumbing Experts
    Jim Goldsmith
    Jim Goldsmith
    Mack Baxter
    Andrew Bugbee
    Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
