I want to scan my news articles to my computer from the printer. It keeps asking to scan to a network or a usb cable. What to do?
  • 4,281 Answers
Select Twain option or usb .If still you are not able to scan then open my computer if your scanner driver installed then you can see in my computer scanner wizard then open it and scan your new articles.
If your scanner driver is not installed then you need to install scanner driver for that if you do not have disk then download driver from scanner manufacturer sites.
Then install.
Make sure your usb cable is working fine try with another usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 06, 2010
My brother DCP-J140W won't scan. It keeps saying check connection but it is printing okay. Please help!
How is the all-in-one connected to your computer? The problem usually means that you do not have bi-directional communication between the printer and the computer.
If it is connected to your wireless network, did you ensure that the firewall allows the communication? (Some firewalls will automatically add the correct ports to the allowed list during the install of the full software.) For other firewall software or the less-complete install of the software drivers, you need to make sure that the port, 54925 , are allowed to access your computer for inbound and outbound network data. If adding that port is insufficient to allow scans to have bi-directional communication with the printer, also add port 137 (inbound and outbound). Since this step depends on your firewall, please add a comment with the firewall software on your computer. This is in the note in the Scanning section of the Brother Software User's manual for the DCP-J140W on page 35. This manual is available here: http://download.brother.com/welcome/doc002923/dcp140w_use_soft.pdf . An example of setting the Firewall rules for the Windows Firewall is shown starting on page 85 of the manual.
If your computer is connected to the printer via a USB cable, try a different (possibly shorter 6' or less) USB cable or a different port. If you have the printer connected to a USB hub, skip the hub and directly connect to the computer. Check if other devices work at the USB ports. Sometimes ports do fail; either they can't maintain the needed voltage or they don't keep the cable and pins properly aligned.
I hope this helps.
(I have seen the communication issues with stand-alone scanners as well. I saved a perfectly good scanner from the trash when the user failed to check if the scanner worked with other ports.)
Dec 16, 2013 | Brother DCP-J140w Wireless Compact Inkjet...
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
Won't print, I can scan, but it won't copy or print anything. Just pulls the paper in and sits there doing nothing. I can scan though. It won't print anything. won't work directly connected to computer or...
I understand..what u need to do just disconnect the usb cable..put the cd in...go to computers>>right click on the cd icon>>explore>>utill>>ccc>>uninstall l2...then restart the computer..dnt connect the usb..reinstall the printer...whenever it will ask u to put in the usb cable do that...best of luck..
Mar 24, 2010 | HP Officejet J5780 All-In-One InkJet...
Dell a920 network problem
I will assume you have the Printer connected directly to a PC via the USB printer cable on our network.
a. Start - Run - Control - Ok
b. Open 'Printers and Faxes"
c. Open "Dell A920"
d. Print "Test Page" to assure the printer is working and connected.
e. With the "Dell A920" properties open - find the tab for Sharing.
f. Now select Share the Printer and name it.
At each Workstation you will need do steps a-b, and add the printer. Select browse network when adding the printer and find the Workstation with the shared printer.
If your Firewall on each Workstation is blocking "Print and File Share" you will need to change the settings to allow this procedure through.
Here is a link that may help further.
http://www.smartcomputing.com/Editorial/article.asp?article=articles/webonly/techsupport/73w10/73w10.asp&guid=
Hope this helps.......
God Bless.......
Jul 28, 2009 | Dell A920 InkJet Printer
Printer keeps saying usb cable not connected
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 19, 2008 | HP Photosmart C4280 Aio Printer
Scanning problem
This seems like you haven't installed the toolbox correct, please send more info.
Have you printer connected by usb cable or in a network(scanning doesn't work on a wireless)?
If on a network, use web browser and through EWS on printer see for network tab and SNMP enable read/write, print public in the 4 fields choose apply. Download fix scan utility from HP web and install. Restart the pc and set up the scan in toolbox and try scan again.
Sep 26, 2008 | HP LaserJet 2840 Printer
SCAN to pc useing Copystar 1820
please specify how the machine communicates with computer (network, USB cable, or parallel cable). once this is known I'll be able to tell you how to setup the scanning.
As for the 2nd question, yes this machine does support vista, both 32 and 64 bit
May 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Scan not scan to pc or email
Deifinetly. Scanning only works through the USB cable. Make sure you buy a good quality one. And do not exceed 10 ft length without using a USB active repeater extension cable.
Apr 30, 2008 | Samsung SCX 4521F All-In-One Laser Printer
TRYING TO CONNECT HP LASERJET 1320N TO COMPUTER
unplug the usb from the pc and power down the printer,
then power it back up and plug in to pc see if the computer sees it and then continue the install of the drivers
Dec 06, 2007 | HP LaserJet 1320 Printer
27 people viewed this question
k24674
