Question about Proficient S12 Subwoofer
PS8 Subwoofer started buzzing non-stop
New PS8 Subwoofer started buzzing non-stop, buzzes when plugged in (whether connected to receiver or not) Checked the one 250V fuse, looks ok, but doesn't buzz when the fuse is out... Has it gone bad, or do I just need a new fuse?
  • 21 Answers
With nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
Posted on May 07, 2010
I have a constant buzz tone coming from my subwoofer. I checked power connection, fuse and volume/crossover settings and nothing makes the tone go away. is there anything else I can do? Is it repairable?
Hello,if your subwoofer cable has gone bad this will introduce a hum(buzz) into your audio.I suggest replacing the subwoofer cable, a standard rca cable will do,and see if the audio cleans up.
Sep 11, 2010 | Snell PS.10mk2 Speaker
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Loud buzzing when switched on. Not connected to receiver. Should I open up the back of the subwoofer? Bad fuse? Thanks, RC
If there is a buzz and the lights are on its prabably not the fuse. If the buzz is being heard from the speaker than the speaker is okay. the amp may be blown
Jan 17, 2010 | Audio Players & Recorders
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
Subwoofer stopped working
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Buzzing sound from woofer when I plug in
If the woofer works fine when plugged into any other port, I would say that you have a connector on the receiver that has a loose connection or possibly a cold solder joint (poor or broken solder joint). RCA jacks can be stressed quite a lot especially if you use cables that have very tight connectors. The female RCA jack gets wiggled or twisted when trying to remove a cable and this causes solder joints to crack. I would have a look at that connector on the receiver..
Mar 02, 2017 | Panasonic CT-35SF23 35" TV
Buzzing Cerwin Vega LS-12 Subwoofer
Generally, a buzz from your sound equipment indicates some sort of nearby EMI. The normal culprits and.or possible fixes that I've found are:
- Remove any other electronic devices plugged into the same outlet as your subwoofer
- If the woofer is on a power strip/surge protector, remove it and plug directly into the wall
- If there are any nearby wireless devices (cordless phiones, WiFi eqiupment), disconnect/power down them
- Try connecting different speaker wire between the woofer & the receiver
- Try turning off all other eletronic equipment with the exception of your receiver
Let me know if any of these help and good luck!
Nov 27, 2007 | Audio Players & Recorders
Proficient S12 Subwoofer Logo
702 people viewed this question
Top Proficient Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
