Question about Keurig B50 Coffee Maker
Does not pour the proper cup size. Have the default set to the largest size. Sometimes it pours the proper size, other times it pours a smaller size. Also, the sequence of action seems to be off. Sometimes it pours immediately, other times it takes time to replenish the reservoir. Seems inconsistent.
    Sniper:
  • 92 Answers
The Keurig is supposed to keep at least 12 OZ of hot watet at the ready...
when you press brew, the pump pushes water into the bottom of the heater... the hot water comes out the top into a clear plastic holder with probes sensing the height of the water... when the proper height is reached, the motors change state... other valves open up and that pur-measured water goes from the plastic holder tank to the arm touching the K-Cup...
Try running vinegar thru the unit and maybe the sensor probes are scaled... otherwise... you may have a intermittent connection and would beed to reseat the low voltage wires from that water height container...
involved taking the unit apart... :(
try the vinegar first.
Seems like internal cables need reseating.....
I posted how to open it... do not do unless its out of warranty... and you have a few hours of time to disassemble it...
Posted on May 06, 2010
It wont brew
Carefully clean the sharp pin that pouches the hole in the top of the k-cups by inserting a toothpick or paperclip into the hole where the water is pushed into the k-cup.You need to descale it by cycling some vinegar and water through it. Pour a couple cups of vinegar and a cup of water in the reservoir push the large cup size, you can reuse the vinegar mix just don't pour any grounds back into the resevoir.Do this several times (you should see noticeable improvement)then run some clean tap water through so your coffee doesn't taste like vinegar. Hope this helps!Justin
Mar 29, 2014 | Keurig Coffee Makers & Espresso Machines
Coffee is way to strong
Change the settings to Large Cup.
Jan 07, 2013 | Keurig Platinum B70 Coffee Maker
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Size Cup Malfunctioning
you might want to descale it with vinegar at least a few times.
Jul 10, 2017 | Keurig B60 Coffee Maker
Sometimes it pours only 1/2 a cup
clean the cup holder and clear the sharp tube . These get clogged from use, especially from cocoa
May 17, 2010 | Keurig Elite B40 Coffee Maker
I need cleaning instructions
I used an air-compressor with a small soft rubber nozzle, and blew out the rubber over-fill port, the peircing needle and the reserviour inlet, and it started working like new. I have done this to two seperate machines - that were both having short-pour options, and it worked like a champ
Nov 07, 2009 | Keurig B60 Coffee Maker
First cup of the day ony fills half way
Have you cleaned the exit needle? Seem to be clogged up, more info here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 16, 2008 | Keurig B60 Coffee Maker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Keurig B50 Coffee Maker Logo
1,277 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
