Question about Altec Lansing ADA425 3-piece 30-watt Speaker Set Computer Speakers
Need wiring and 9pin connector diagram
For Altec lansing model A425 satelite speakers and sub woofer 9 pin connector wiring diagram. My plug from the satellite speakers to the subwoofer is broken, need pin order for the 9 pin plug. email: Thank you
  • 2 more comments
  • Anonymous Mar 13, 2009
    Same problem. It is a db9 connector.
  • harshit Jul 04, 2013
    where i get 9 pin wire plug in gurgaon?
    tell me how to solve it?
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
Posted on Mar 24, 2009
  • jerz4ever38
    jerz4ever38 Mar 02, 2013
    What should I do if I want the subwoofer only? I want to discard the 2 satellite stereo speakers, but want to be able to use the subwoofer by itself with the volume knob. Do you have any suggestions? Thanks.
    New Friend:
  • 8 Answers
Wiring and 9pin connector diagram posted here
need wiring and 9pin connector diagram - need-wiring-9pin-connector-diagram-1csh141n0ivntjt0heqsbdeb-3-0.jpg
Posted on Aug 23, 2015
Ca i get a main chip(IC) number
Posted on Jun 11, 2012
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end systems components that depend on each other and cannot be interchangeable from other system. So if one of the components (sub woofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a sub woofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible out of the box. Speakers are also glued together so it is impossible to open without damaging it. Not to mention there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information bellow:
Altec Lansing VS4121 connector pinout
If you take the male connector (from right satellite speaker) and look at the pins and number them first row from left to right pins 1-3, second row pins 4-7, the bottom row pins 8-9 and the circle enclosure as 0
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Head Set Left
6 - Ground for Head set (grounds 0 and 6 seems to be connected in the subwofer but within the right satelite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or head set jack plugged = 0V; When ON and head set jack unplugged = 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone sub woofer you will need to implement:
- Power On.Off (switch between pins 8,7)
- Volume control (50k potentiometer (probably anything beteen 10k and 50k will do)between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and lets call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should bypass anf frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS 4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
Jun 25, 2012 | Altec Lansing VS4121 Speaker
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
I found that one of the pins of the plug connecting the sub-woofer was bent and the plug was not seating properly deep in to the slot. Every pin has a specific task to the sound system, it seems. I set right the bent pin with a long needle gently and re- plugged in to the woofer's slot. After that every thing works amazingly. All it requires is patience and application of mind for a while exclusively focused on the problem.
Thanks and regards
M. Narayanan
Jan 15, 2010 | Altec Lansing Audio Players & Recorders
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card manual: is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
7,522 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
