Question about Kenmore 73952 Gas Dryer
Kenmore model 417-how to get to fuses in control panel. 03 model
DRYER WON'T HEAT- MANUAL SAYS PROBABLY 2 HOUSE FUSES BLOWN- HOW CAN I ACESS THEM?
    Genius:
  • 1,122 Answers
Unplug remove the back and you will see one fuse on the left side of heater box,and the other on the blower box(white)
Posted on May 09, 2010
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Kenmore dryer will not heat up to dry clothes. serial# MD0748533 mod# 97281100 72811
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes.
Based on the information provided above, I am unable to provide a positive solution to your issue.
Following this LINK, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User's Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This information is for an electric, generic model dryer only!
My Solution is:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 26, 2010 | Kenmore Dryers
My kenmore 81492500 manual suggests if the drum is turning, but not heat, there are 1 of 2 house fuses are blown. Where are the fuses located in the dryer circuit?
the fuses are in your house fuse box,with a meter check to see if you have 220 to 240 volts or 110 to 120 to the black and white wire and 110 to 120 to the red and white wire where the cord connects to the dryer,if you do you'll have to check the heater,the high limit thermostat on the heater box,the thermal fuse on the blower wheel housing,you have to unplug the dryer to do this and pull at least one of the wires off the part you're checking.next time send the first three small black numbers on the model number with the 81492500,
Apr 22, 2010 | Kenmore 62982 Electric Dryer
We have a kenmore electric dryer runs with no heat. repair manual said to check fuses. House panel has circuit breakers none tripped manual says there are two house fuses in the dryer circuit. If one of...
Older fuse panels would have two fuses, one provides power from each 120 volt leg in the panel, therefore providing 240 volts for the heater coil. The motor in the dryer only requires 120 volts, so it may possibly still run if it is on the side with a good fuse. In newer panels that have circuit breakers, you may only have a single handle, but the breaker is a 240 volt breaker (which controls both 120 volt feeds at the same time). You will likely notice that this and all other breakers that are 240 volts are twice the width of a single 120 volt breaker. There is no "second fuse" for you to check, as the circuit breaker takes the place of both fuses in an older style panel.
If you are able to confirm that you have good power at the power connection at the back of the dryer (120 volts between black and white, 120 volts between red and white, 240 volts between red and black wires), then that typically only leaves the heater coil itself or the timer to check. Check continuity on the heater coil first, and visually inspect it for a broken or shorted coil. It is usually the culprit.
If the coil checks ok, carefully check the voltage at the terminals that feed power to the coil. Depending on the model, there may also be a thermal fuse or thermostat that is inline with the power feed to the coil itself. Check this to make sure that it has continuity as well.
I hope this helps you with your repair troubleshooting. Good luck!
Mar 13, 2010 | Kenmore 62602 Electric Dryer
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
No heat gas kenmore gas dryer
Dryer won't heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Dryer won't heat
Your issue is;
"I have an older model Kenmore dryer that won't heat up. Need to know what could be the problem."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
This link provides diassembly procedures for a similar model.
http://www.repairclinic.com/0100_15.asp
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
Heating element
Thermal fuse
Wiring
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 24, 2008 | Dryers
Kenmore HD gas dryer won't heat up
Heating element
Thermal fuse
Wiring
Jul 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73952 Gas Dryer Logo
581 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
