Question about Honda Transfer Kit for EU 3000iSAC and EB 3000CKAG
Eu3000is won't start............has spark at plug.........has fresh fuel.........has clean a/f................valves are not tight.........
  • garyandjo67 Jun 12, 2010
    three days ago i gave up (today is jun 12,10) cause all book cks and cks we're good-----problem appears to have been internal carbon/something ...........decarboned/cleaned with spray carb cleaner thru carb then once i got it started continued 4 minutes of short blast thru carb inlet while it was running. Runs smooth now and starts great. thx for following me people
  • 905 Answers
Check for restricted exhaust, sheared woodruff / flywheel key.
Also check the overtemp sensor, as well as oil pressure / level sensor as well.
Posted on Jun 12, 2010
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 14, 2013 | Ducati Motorcycles
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Petrol mower won't start
Could be any number of things, start with fresh fuel and a new spark plug, then check the flywheel key has not sheared, make sure the blade is tight, if not better it may be the valves have burnt and are now not seating.
Apr 15, 2012 | Garden
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Lt180 won't run without choke pulled out..replaced fuel pump, gas,.2 spark plugs...fuel filter looks fine & carb was replaced last year.
Hi, disassemble and clean all jets in the carby, also check the valve clearances are correct because if they too tight the engine will not draw fuel in. Hope this helps, regards Phil.
Jul 14, 2011 | John Deere Garden
Not getting fire over the #1 spark plug coil. What needs to be changed/what is the cause of the problem? The engine stopped running while in motion. Battery light came on first then all the other warning...
  1. Check fuel level in fuel tank, add fuel if empty.
  2. Check battery condition and state of charge. If voltage and load test below specification, charge or replace battery.
  3. Check battery terminal and cable condition and tightness. Clean terminals and replace damaged, worn or corroded cables.
  4. Check fuel delivery system. If fuel is not reaching the fuel injectors, check for a loose electrical connector or defective fuse, relay or fuel pump and replace as necessary.
  5. Engine may have excessive wear or mechanical damage such as low cylinder cranking pressure, a broken camshaft drive system, insufficient valve clearance or bent valves.
  6. Check for fuel contamination such as water in the fuel. During winter months, the water may freeze and cause a fuel restriction. Adding a fuel additive may help, however the fuel system may require draining and purging with fresh fuel.
  7. Check for ignition system failure. Check for loose or shorted wires or damaged ignition system components. Check the spark plugs for excessive wear or incorrect electrode gap. If the problem is worse in wet weather, check for shorts between the spark plugs and the ignition coils.
  8. Check the engine management system for a failed sensor or control module.
May 21, 2011 | 2000 Mitsubishi Galant
My 99 Focus will not start. Fuel supply is OK. Fuel injectors have power. Spark plugs are firing. Engine turns, but will not even try to start.
Apr 27, 2011 | 1995 Mazda 626
Wont start
When you replaced the spark plug, did the plug show a snappy, blue spark when the engine was pulled through smartly? If it did, check for a plugged fuel filter, air cleaner, and muffler. Check the fuel lines for condition. Make sure the carburetor fasteners are tight. Does the primer pull fuel into it? Is the fuel mix fresh? If still nothing, try spraying some starting fluid into the cylinder through the plug hole and pull through. If pops several times, the carburetor may need to be disassembled, cleaned and adjusted. Hope this helps!
Apr 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Honda Transfer Kit for EU 3000iSAC and EB 3000CKAG Logo
272 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
