Question about Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer
My sounder works very eratic. Sometimes it works and sometimes not. Most of the time it is just flashing 0.0ft. The speed and temp both work fine.
What version software are you running in your 498?
Posted on Oct 20, 2011
  • dnbloch
    dnbloch Jul 11, 2012
    coastal waters
Mine does the same thing. i plugged in my old gpsmap 168 sounder, and depth works fine! so i "assume" it's something inside the 498 . . . I'm going to try buying a new 498 because i don't want to mess with the wiring or the mount
Posted on Jun 04, 2010
Whirlpool LHW0050PQ4 Front load stackable door switch eratic
Go to whirlpool.com and download manual. download from owner icon
Dec 11, 2011 | Whirlpool Washing Machines
Toyota Carib 1995 1760cc 117000km, eratic idling sometimes at 1.5 and other times 0.5 ! Replaced IAC valves, Did total engine overahaul, computer diagnosis does not show and fault ! New battery new spark...
replace ur air flow sensor, make sure ur injectors are clean and properly working, also ensure that the distributor is fine and coil should give out standard/optimum voltage. Please vote if it works. Good luck.
Jun 23, 2011 | Toyota Corolla Cars & Trucks
Hello, my Humminbird 565 startred to misread the tempereture, when stoped or in low speed it show the water temp 10º c bellow the real temp. The same happens in Fº. The sounder otherwie works...
More than likely you have your sensor run underneath the boat and therefore the sensor is directly in the water. When you speed around the hot water on top is what your sensor is picking up, when you slow, you are allowing the sensor to pick up on the colder water just inches below the surface
Jun 03, 2010 | Humminbird Fishfinder 565 With Transom...
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Sometimes mouse freezes up. new battery.computer runs on vista. when you want to click on something it works sometimes and sometimes it just freezes
That problem is usually a driver issue. when you plug the mouse the drivers are not properly configured and thus communication between the computer and the mouse becomes eratic. Visit the Manufacturers website and see if they have any updates. Also make sure your mouse is compatible with Windows Vista... Windows Vista did come with quite a few compatibility issues...
Finally make sure you don't have any resource conflicts. Sometimes new hardware can take on resources that are being used by another piece of hardware thus the eratic behaviour
Jan 17, 2010 | Logitech Cordless Mouse
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Misfire and eratic idle on Ford Focus petrol 1.8i
motor mounts need replacement and sounds like your cars comp. is about to take a hit and go down
the air flow control unit sounds like it also has has a clog in it and needs to be serviced this is a big one when you get to driving at higher speeds the fan turns off and the air outside controls cooling air/fuel mixture rate sometimes too much air intake can make the vehicle act eratic
May 21, 2008 | 2000 Ford Focus
Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer Logo
391 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
