Question about Sanyo North America Plcxw200 Xga 2200 Lumens Classroom Wnet Projector
No indication power is getting to the unit. no lights, nothing happens when on button pushed. Re:PLC XW200
  • 144 Answers
Try using another power cord and make sure that the lamp is replaced,cleaned,and also securly fitted.
Posted on May 08, 2010
47pfl56030d/27
If the front panel indicator lights, power is getting to your TV. Pushing the power button and getting no results indicates that something is wrong with the internal power supply
Jan 04, 2013 | Philips 47PFL5603D/27 Flat Widescreen TV...
Sanyo plc xp100 - all indicator lights are flashing when turned on
I have only experienced all the indicators flashing after 3mins of powering up and then suddenly shutting down. I have not yet experienced the indicators flashing straight after turning on.
I think the problem for me was that the filter wasn't seated firmly enough in the filter compartment. I was able to stop the indicators flashing by turning off the power at the power point, removing and reinstalling the filter, making sure that it fit firmly and tightly in the compartment. Then I turn the power back on. I believe that sometimes if the filter isn't set in the compartment tightly enough the projector will think that no filter has been installed and will automatically shut down after 3 mins.
You also need to make sure that the filter has not run out of scroll. to test this, push down the small, white spool on the left whilst pushing down and turning the large geared spool on the right anticlockwise. If the filter continues to scroll you can still use it. If not, the filter has reached the end of the spool needs to be replaced.
May 09, 2012 | Sanyo PLC-XP100L Projector
Hi, There was a popping sound from my PLC-XL50, then the projector turned itself off. I noticed that rather the replace lamp light being lit, the warning light is on. Does this mean the lamp has died...
This is an indicator stating the lamp is bad and cannot power the projectors backlight. You should replace this prior to any additional powering of the unit.
Sep 22, 2011 | Sanyo PLC-XL50 Projector
Is it possible to use the Sanyo remote control to progress the powerpoint presentation, or is that only done through the laptop
It is usual to progress it with the mouse and I use a wireless mouse, it goes down really well at each presentation as they all think my naration timing is impecable!
Mar 22, 2011 | Sanyo PLC-XW200 Projector
Pushed the on button, the green light comes on,
Green light comes on, what about other indicator lights? Is there activity like fans humming. Try to take out the battery and power up using the ac adapter only.
May 12, 2010 | Acer Aspire One PC Notebook
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
I push wall button and hear clicking but won't open
Try unplugging the operator. This may reset any problems you had.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Sanyo PLC XU48 problem starting
Service and reinstall main PCB connectors and cables including sensors. check the lamp condition also.
Viren
Nov 24, 2007 | Sanyo PLC XU48 Multimedia Projector
Sanyo North America Plcxw200 Xga 2200 Lumens Classroom Wnet Projector Logo
98 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
