Question about Garden
I replaced the carburetor , the engine starts but doesn't run smooth. Toro Lx425
  • 2 more comments
  • dlozen801 May 06, 2010
    New fuel filter and plugs were installed yesterday... Any other Ideas. Possible carb adjustment or messed up linkage?
    -Dennis
    Alas, I put a brand new air filter on the engine when I replaced the carb and also a brand new fuel filter.
    Is it possibly bad fuel?
    -Dennis
  • dlozen801 May 07, 2010
    Aha, It doesn't run rough when it's loaded with the dexk. I'll adjust the idle tomorrow...
    Thanx,
    -Dennis
    We worked right through to the only logical solution for the problem. Thank, You...
  • 708 Answers
Try changing the spark plug on it. It could be fouled out. Also, you could be starving it for fuel, check the fuel line and make sure it is not kinked or clogged. Depending on its age it may be time to replace the fuel filter on it also.
Posted on May 06, 2010
  • 1 more comment
  • Chris Yelton May 06, 2010
    what does the air filter look like? I had one that ran rough, but the air filter was very dirty. did you check the fuel filter and fuel line?
    It could be bad fuel. My 20hp briggs would run sluggish with 10% ethanol but it wasnt that ruough. If you are trying to use last years gas then I would say thats it. Get some fresh fuel for your mower and dump last years in your car. Your car can mix it with the fresh gas and run fine, your mower cant.
    Since you rebuilt it you may have to readjust your idle on the carb. If it is too low it will idle rough but should be fine at high idle. Is it rough at high idle too?
    check the gap on your spark plug too.
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
How do i replace a drive belt for the toro lx425 lawn tractor?
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Oct 10, 2010 | Toro Garden
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
Lawn mower turns over starts running then quits
This is probably related to a carburetor problem. Try removing the brass bolt that holds the carburetor bowl on the car. Clean any sediment and water out of the bowl and inspect the brass bolt. There are very small holes at the bottom and along the smooth part above the threads. This is the carbs main jet and all these small to tiny holes need to be open for the carb to operate correctly allowing the engine to run.
Jul 10, 2010 | Toro Garden
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Frozen blade spindals
Yes apply some heat and it will break it lose and the system will spin just fine
Feb 13, 2009 | Toro Lawn Mower With Toro Power Tools
Toro LX425 wiring harness
The blades themselves don't really matter. If the hood has a safety switch, then all you need to do is bypass it with a jumper wire. Other than that, you should be all set.
Feb 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Oct 05, 2008 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
