Question about GE GSH25JFR Side by Side Refrigerator
Dispenser unit nonop on GE side by side fridge (model GSS23LGTA)
I have a GE side by side fridge (model GSS23LGTA) about 3yrs old. The dispenser unit on the front stopped working. It won't dispense water or ice. The ice maker inside is working fine. The 'water' indicator comes on when I push its button, but goes off when I press the dispenser handle. If I keep the dispenser handle pressed, it gives a light click every 2 sec, and the 0 for the freezer temp flashes. I have a feeling something's broken in the circuitry. Any ideas?
  • 184 Answers
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Posted on Apr 10, 2008
maklean
  • 1665 Answers
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 16 Answers
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Posted on Jan 23, 2009
  • 686 Answers
SOURCE: Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Posted on Feb 20, 2009
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag Water Dispenser Problem
If your water supply line is not pinched closed somewhere and the fridge has electricity supplied then it may be the solenoid operated water supply valve that has failed. This electric actuated valve should open when you activate the switch in the door with your glass.
May 03, 2008 | GE (GTS16BBS) Top Freezer Refrigerator
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JFR Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
