Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire elec.dryer runs but wont dry,model#GLEQ642AS2 need repair manual
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. For more details see the link and kudos to heatman101---
Dryer Won’t Dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 06, 2010
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
There is a squeaking sound when running the dryer
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Nov 28, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ642AS2
Sounds like a wire problem. Frist unplug the unit. Then take the cover off where the wires go in the back to check for a burnt wire. If that is ok you need an amp meter to check for the heater amp draw. You could have a weak breaker.
Apr 24, 2008 | Frigidaire GLEQ642A Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
80 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
