Question about Brother MFC 420CN All-In-One InkJet Printer
Can't fax multible pages
I have a brother 420cn all-in-one printer, I have been faxing with it and never had a problem. When I try and fax mutliple pages it will only send one and comes back with a transmission error saying "poor line/ out of memory. I have checked the line but don't know what the out of memory means. Can you help me?
    Guru:
  • 1,049 Answers
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
Posted on May 06, 2010
Hi i have a brother lc67bk fax printer it won't fax as memory full how do i clear
LC67BK is the Part No. for the Black Cartridge so I presume your Printer Model No. is MFC-420CN as detailed in the heading.
PDF Manual for this model is at the link below which explains about faxing multiple sheets using internal memory.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057875.pdf
Jul 23, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-420cn - fx problem
From the manual for your Brother model: To select or change your Receive mode 1. If it is not illuminated in green, press "Fax" (picture of Fax button) 2. Press - "Menu/Set, 0, 1." 3. Press - (up arrow) or (down arrow) to select "Fax Only". 4. Press - "Stop/Exit." This is just to select the "Fax Only" option, which is what you need - having a phone line strictly for the fax machine. There are 4 options on that setting, and the manual explains them in more detail. You can also set the "Ring Delay" for the fax by pressing "Menu/Set, 2, 1, 1." The options shown are "0, 1, 2, 3, or 4". It's very likely that you want to select an option OTHER than "0". This Brother manual for your model can be found at this URL: --> http://www.retrevo.com/search/fv/1d4caef84f3754461d7ce187341b923c.pdf#page=1 Hope this helps! If not, let us know and we'll try to help further. ;)
Aug 09, 2007 | Brother MFC 420CN All-In-One InkJet...
How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Aug 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Scanner and fax help.
getit here:
u may have to make a quick free acct
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
its for 420CN and 210C,hope it helps!
Nov 23, 2008 | Brother MFC 420CN All-In-One InkJet...
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Fax
On this page, you can download the User's Guide.: see sections 2-5:
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-420CN
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 14, 2008 | Brother MFC 420CN All-In-One InkJet...
Fax memory
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=mx&lang=es&prod=mfc420cn_us&Cat=11&ot=us_ot
Nov 15, 2007 | Brother MFC 420CN All-In-One InkJet...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother fax model mfc-420cn not working
This is how you can get your instructions. goto your favorite search engine.Enter Brother fax machine support. Goto the the site that has brother manufacture and look for the support tab. Once there you look for your model number and then select it. It will give you downloads for drivers , manuals and technical information
Sep 19, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
144 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
