Question about Mitsubishi VS-55705 55" Rear Projection Television
Mitsubishi projection 55 inch
When I turn my Tv on it's got these lines running horizontal and move very fast up and down. For a while if I leave it on for about 15 min. it would come back to normal but now the lines are there for good. Please help
  • Anonymous Sep 05, 2008
    I HAVE A 45 WHIT SAME PROBLEM THERES IS ANY WAY TO FIX IT BY MY OWN?
  • tomyeager042 Mar 06, 2009
    picture does not hold still when first turned on. Very wavey or jumpy. At first problem only lasted for a minute or so. Now it lasts for about 15 minutes and then it is ok. Seems to be getting progressively worse over time.
    Scholar:
  • 77 Answers
A couple of things come to mind I've seen a leaky capacitor on the regulated 9 volt line cause this and also leaky capacitors on the PIP module but I think the latter was on an older model than yours. If you don't know what these things are you should probably let a pro do it but it should be a fairly reasonable repair. Good Luck.
Posted on Apr 04, 2008
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 55
Your DMD mirror bracket may be loose, screws may just need tighten down or a pin may be missing in the bracket too. If it is not the bracket then you need to replace the DMD board itself.
Mar 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 56 inch rear projection TV
A 22 code in Mitsubishi is a short circuit that is causing your set to go into protective shut down. Check the horizontal output and low voltage regulators for being shorted. Let me know if I can help you further, or if you need any additional info.
Jan 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Going down fast
Its definately fixable. Can you post a picture of what your refering to when you say horizontal lines and jumping? Also do you have any soldering ability or troubleshooting experience? Let me know
Jan 12, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
228 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
