Question about ASUS P4B533 Motherboard
I have a Asus P4b533 motherboard that that started long beeps the manual says that its the ram how can i install the right ram 3 slots
  • 416 Answers
You could be having a defective RAM. try your RAM on another PC or replace the RAM with a new one. it does not matter where you install the RAM ( any one of the three slots)
Posted on May 06, 2010
One beep, quick pause, then constant series of beeps. Memory, cpu, power supply replaced. Shows the Asus boot P4B533 graphic on screen while error beeps. I get the proper related error beeps if memory, agp...
It does sound like the motherboard failing as you have tried everything possible. Could be the bios chip corrupted.
As to a replacement, Ebay is your best bet, as there do not be any suppliers offering this older board now
Jan 15, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
No sound
click start control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 01, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
Asus P4B533 gives single beep at boot after installing Corsair 1GB PC2100 double sided ram in slot 1 by itself. No problem when 2 Kingston 256 MB single sided in slots 1&2.
These motherboards, as with most manufacturers, seem to have preferences for specific makes/models of peripheral gear, especially for RAM chips. Consult your motherboard manual for compatible RAM, and proper placement in the RAM slots. Also, consult the motherboard vendor for info in this regard. They may have specific experience with this motherboard that can steer you toward the proper RAM to use. ie, it is in their interests to have satisfied customers for repeat business, by supplying peripheral items that function reliably with the motherboards they sell. Don't delay, since this technology, and the items that stores carry change at an ever-faster pace. Also, don't cheap out by using RAM of questionable fit for this motherboard.
Please feel free to get back to me about your situation.
Oct 27, 2010 | ASUS P4B533-E (P4B533-E/L/1394)...
Are the connections on my P4B533 PCI or PCI express & should I install a new viedo card in theagp slot or?
Sorry, you only have 6 PCI slots and one AGP slot. None of the slots are PCI Express. For some general dimensions of PCI Express slots, look at the this picture.
Dec 31, 2009 | ASUS P4B533 Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
There is an inbuilt speaker but the sound is not coming
Hi gogovie_2,
There is only one speaker controller (C-Media 8738-MX), built into the P4B533 motherboard which is where you would connect a home speaker system into the lime green port located at the rear of the motherboard. (See your manual, page 1-7 for the motherboard layout & location of the line out jack for your speaker plug). See pages 1-8, 1-9 & page 1-10 for descriptions of each item shown on page 1-7.
The ASUS P4B533 MB usually comes with a small black speaker that plugs onto the motherboard. You can see the location for this speaker on page 2-33. Number 18 shows the configurations for the 20-pin panel & internal speaker.
This tiny speaker is used for system P.O.S.T. Known as Power On Self Test. During the boot up process a single beep will sound off. This tells you that the motherboard bios has passed P.O.S.T.
If you need the manual for the ASUS P4B533 motherboard you can download it directly from Asus. Click on the link below. Once the link has loaded type the model number, P4B533 in the search window (Upper right hand corner) & click the white arrow.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Click on, " P4B533 related files for download ". The next window will want you to click the dropdown menu & choose your operating system. (Do so). Asus will display all drivers, manual & bios files for the P4B533 motherboard. If you download the manual you'll need Adobe reader to view the manual. You can download Adobe for free at this next link; http://www.adobe.com/products/reader/
If you do not have sound from your home speaker system make sure you have installed SoundMax/C-Media software. This program uses jack auto detecting censer software to help setup your speaker (s). You can also download the latest audio drivers.
If you think you need a new (Internal speaker) you can buy one from here; http://www.pcpartscollection.com/mosp.html
& from here;
http://www.anitec.ca/product/11692/generic_4_pin_speaker_for_motherboards/
Lastly, if the information provided here has not answered your question, please rephrase your question. I'm sure I can provide you with an answer & fix.
Mike
Feb 03, 2009 | ASUS P4B533 Motherboard
ASUS P4B533 Motherboard Logo
138 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
