Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
When I pug in my WD 320GB drive I can see the files but when I try to unplug it I can not see it to stop it. But the pc alerts me that I have uplugged a device without stopping it. I now seem to have developed a loose connection at the usb port. How do i open the HD to change the casing
  • amoclue May 06, 2010
    There are no screws on WD320 GB external hard drive. How do you open it and how do you see it to stop it when unpluging it
  • 4,281 Answers
There should be some lock system if there are not any screws.
Open that lock and then pull harddrive casing.
Then you can open it.
For stop issue.
Make sure your usb cable is working fine.
Then uninstall usb drivers then it automatic install all usb drivers.
For that right click on my computer then click on property then hardware->device manager.
then you can see all driver list then uninstall all usb drivers 1 by 1 .
Also scan your harddrive with updated antivirus.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 06, 2010
  • 13,433 Answers
Hello
the casing is most likely held in place with a few screws, possibly hidden under a label, go over each inch of the drive to find them.
after the screws are out (if any exist) then you need to use a plastic stick or a case opening tool to get it apart, it is held in place with plastic clips.
It is very simple from there. Just unscrew the drive and take it out, then put it into a new case.
let me know if you need further assistance.
  • Ekse May 06, 2010
    You need to use a plastic stick on the edges / openings of the device to get it to snap open, small plastic clips hold it in place. you go around the whole case until it opens up.
  • Ekse May 09, 2010
    hello? i've not heard anything back from you? do you need further assistance? if not, please click on the accept button below my solution.
WD MyPassPort 320 GB partially dead after an attempt to make it Win8 recovery drive.
Maybe you can try to format it to see if you can get the space back. But one thing important is that you may need to backup your files first. If not, you may lose them. Or you may try some file recovery tool after you format your drive. This may be help, I've try it, workable. http://www.uflysoft.com/data-recovery-mac/ Hope it can help and hope you can get back your 320G back.
Jul 16, 2013 | Western Digital Wd 320gb My Passport Elite...
Plug hard drive from pc to mac now i cant open files on my pc and the icons have a short cut icon on them?
It appears to be a problem with the WD hard disk that has data that the PC cannot read.
I suggest you format the WD hard disk.
The WD hard drive must be formatted on a PC in FAT32 for you to exchange data between the MAC and the PC.
This will allow the MAC to see a PC hard disk and write files to the WD that the PC can open.
Apr 14, 2011 | Western Digital Passport 320GB External...
Need to recover files from WD drive that was attached to IMAC when it shut down from Kernal panic. Files were there, some files remain. The files that remain are the ones on the drive before I downloaded...
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good Mac HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Mar 26, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
WD 320 GB ceased spinning
ensure it hasnt damaged and that you didn't passed a magnetic field through it, so that you damaged the sytem files of the hard drive...
Sep 16, 2009 | Western Digital Passport 320GB External...
My WD 320GB Drive is Not Recognized by my comp; it says Reformat
Tru connecting to a different computer. If you have a driver provided with your Hdd, try installing it first.
Sep 01, 2009 | Western Digital 320GB MyBook External USB...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
http://support.microsoft.com/kb/330174
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
Feb 22, 2009 | Western Digital Elements powered by WD 320...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
76 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
