Question about Symbol MC9000 Batch Barcode Scanner Line cord for power supply
Upon Launching my scanner application Telnet - I am getting this Error: Error A0000027 enabling scanner. Scanner support has been disabled. any help would be most appreciated.
SOURCE: KM DiMage Scan Elite 5400 II
If the door to the scanner is actually closed, or the film holder is stuck on it you may have to press the door and film holder in slightly, then let the film holder out while holding the door in. If the door is not actually stuck on the film slider then you should be able to convince the scanner to push the film holder out by turning off the slider and turning it back on again without the software on.
Posted on Feb 24, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
thesuperdude
  • 97 Answers
SOURCE: can't use scanner
You will need to download an application from www.symbol.com called DATAWEDGE. It is free and very easy to use. This application will enable you to scan on to any other application on your MC70.
Posted on Apr 23, 2009
RedMatrix
  • 480 Answers
SOURCE: When the DataWedge 2.0 is
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
Posted on Aug 09, 2011
  • 6 Answers
SOURCE: MC70 Barcode Scanner: how do i enable linear scanner on my symbol mc70...
What you need to do is install a scan utility to enable your scanner. The following postings are old anyone is still having issues?
Posted on Mar 01, 2012
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
Hi, my terminal Motorola MC3190 doesn't want to enable scanner and i really don't know why.... There is an error code A0000032 with message: "CANNNOT ENABLE SCANNER"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software.
Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Nov 09, 2010 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Error A000000B enabling scanner. Scanner support has been disable
Looks like laser head does not work and cannot be recognizied by scanner.
Sep 10, 2009 | Zebra Symbol Technologies MC909X-G Series...
Cannot read symbologie/BarCode: i25(interleaved 2 of 5) from an MC9090-G running VT100 emulation. How do I configure the scanner within Telnet-CE/Wavelink?? Thanks. Dante Barboza
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Jan 06, 2009 | Symbol MC9090-G RFID Handheld Barcode...
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Problem with barcode scanner
Interleaved 2of5 symbologies is normally disabled from factory. what scanning software are you using? have you tried Datawedge to enable the scanner? Is a free download from symbol/motorola and it goes very well.
Mar 05, 2008 | Symbol MC3090
Symbol MC9000 Batch Barcode Scanner Line cord for power supply Logo
278 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
